Help Center/ Web Application Firewall/ User Guide/ Protection Configuration/ Configuring Core Protection Rules/ Configuring Data Masking Rules to Prevent Privacy Information Leakage
Updated on 2026-10-10 GMT+08:00
This topic describes how to configure data masking rules. You can configure data masking rules to prevent sensitive data such as passwords from being displayed in event logs.
Impact on the System
Sensitive data in the events will be masked to protect your website visitor's privacy.
Item
Constraint
Access mode and edition restrictions
  • Cloud CNAME/Cloud load balancer access: This function is only supported in standard, professional, and enterprise editions.
  • Dedicated mode access: This function is supported.
Time a rule takes effect
It takes several minutes for a new rule to take effect. After a rule takes effect, protection events triggered by the rule will be displayed on the Events page. For details, see Querying a Protection Event.
Configuring a Data Masking Rule
  1. Log in to the WAF console.
  2. Click in the upper left corner and select a region or project.
  3. (Optional) If you have enabled the enterprise project function, in the upper part of the navigation pane on the left, select your enterprise project from the Filter by enterprise project drop-down list. Then, WAF will display the related security data in the enterprise project on the page.
  4. In the navigation pane on the left, choose Policies > WAF Core Protection.
  5. In the policy list, click the name of the target policy to go to the protection rule configuration page.
    You can also go to the Assets > Protected Objects page, locate the target domain name, and click the number next to the protection policy in the Policy column to go to the protection rule configuration page.
  6. Locate the Data Masking configuration area and toggle this protection on.
    : enabled.
  7. In the upper left corner above the Data Masking rule list, click Add Rule.
  8. In the displayed dialog box, specify the parameters described in Table 1.
    Figure 1 Adding a data masking rule
    Table 1 Rule parameters
    Example Value
    Path
    Enter the complete URL to be masked.
    • Do not include the domain name in the path. For example, if the URL to be protected is http://www.example.com/admin, set Path to /admin.
    • The path supports prefix match and exact match.
      • Prefix match: Only the prefix of the path to be entered must match that of the path to be protected.
        If the path to be protected is /admin, set Path to /admin.
      • Exact match: The entered path must be the same as the path to be protected.
    • Regular expressions are not supported.
    • The path cannot contain two or more consecutive slashes. If you enter ///admin, WAF will convert /// to /.
    /admin
    Masked Field
    A field set to be masked
    • Params: A request parameter
    • Cookie: A small piece of data to identify web visitors
    • Header: A user-defined HTTP header
    • Form: A form parameter
    Params
    Field Name
    Set the parameter based on Masked Field. The masked field will not be displayed in logs. For example, if Masked Field is set to Params, set Field Name based on site requirements, for example, set it to id. Then, the content matching id will be masked.
    id
    Rule Description
    A brief description of the rule. This parameter is optional.
    None
  9. Click OK. The added data masking rule is displayed in the list of data masking rules.
    To make the protection rule take effect, ensure that the protection policy to which the protection rule belongs has been applied to the target domain name. For details, see Adding a Domain Name to a Policy. A protection policy can be applied to multiple protected domain names, but a protected domain name can be added to only one protection policy.
    After completing the preceding configurations, you can:
    • Check the rule status: In the protection rule list, check the rule you added. Rule Status is Enabled by default.
    • Disable the rule: If you do not want the rule to take effect, click Disable in the Operation column of the rule.
    • Delete or modify the rule: Click Delete or Modify in the Operation column of the rule.
    • Verify the protection effect:
      1. Clear the browser cache and access the http://www.example.com/admin page. If the configured jsessionid cookie field is masked in the /admin directory, the rule takes effect.
      2. On the Events page, check the protection logs.
Configuration Example: Masking the Cookie Field
You can take the following steps to verify that WAF is protecting your website domain name (www.example.com).
The cookie field jsessionid is masked.
  1. Locate the Data Masking configuration area and toggle this protection on.
    : enabled.
  2. Add a data masking rule.
    Figure 2 Select Cookie for Masked Field and enter jsessionid in Field Name.
  3. In the navigation pane on the left, choose Events.
  4. In the row containing the event hit the rule, click Details in the Operation column and view the event details.
    Data in the jsessionid cookie field is masked.
    Figure 3 Viewing events - privacy data masking
