Updated on 2026-09-01 GMT+08:00
Changing the Protection Mode
After your website is connected to WAF, its Protection Status is Protected. You can change the protection mode based on your service requirements.
WAF supports the following protection modes:
  • Protected: If you enable WAF protection, WAF protects your website against attacks based on the protection policy you configure for it.
  • Unprotected: If you suspend WAF protection, WAF only forwards requests to origin servers. It does not scan for or log attacks. If a large number of normal requests are blocked, for example, status code 418 is frequently returned, then you can switch the protection status to Unprotected.
    This is risky. Global protection whitelist rules are recommended to reduce false alarms.
  • Bypass WAF: If you bypass WAF protection, WAF directly forwards requests to origin servers. It does not scan for or log attacks. You need to allow the service port of the origin server in the security policy first to ensure that services can run properly after the protection mode is changed.
    The Bypassed mode can be enabled only when one of the following conditions is met:
    • Website services need to be restored to the status when the website is not connected to WAF.
    • You need to investigate website errors, such as 502, 504, or other incompatibility issues.
    • No proxies are configured between the client and WAF.
  • Bypassing WAF is allowed only if you select cloud CNAME access while adding your website to WAF.
  • Before bypassing WAF protection, ensure that the service port of the origin server has been enabled.
  • If you connect a domain name to WAF with different protection ports configured, bypassing WAF protection is not supported for the domain name.
  • If you bypass WAF protection, requests to the domain name are sent to the backend server directly and do not pass through WAF. Your domain name may become inaccessible if any of the following happens:
    • In the website server configuration, settings for Client Protocol and Server Protocol are inconsistent.
    • Different ports are set for Protected Port and Server Port.
Changing the Protection Mode (Protected/Unprotected/Bypassed)
  1. Log in to the WAF console.
  2. Click in the upper left corner and select a region or project.
  3. (Optional) If you have enabled the enterprise project function, in the upper part of the navigation pane on the left, select your enterprise project from the Filter by enterprise project drop-down list. Then, WAF will display the related security data in the enterprise project on the page.
  4. In the navigation pane on the left, choose Assets > Protected Objects.
  5. Change the protection mode based on your service requirements.
    • Enabling protection
      1. In the row containing the target domain name, click Enable WAF in the Operation column.
      2. In the Enable WAF dialog box, check the impact of enabling protection, obtain and enter the verification code, and click OK.
        After the switchover, the Protection Status field of the domain name changes to Protected.
    • Suspending protection
      1. In the row containing the target domain name, click Suspend WAF in the Operation column.
      2. In the Suspend WAF dialog box, check the impact of suspending WAF, obtain and enter the verification code, and click OK.
        After the switchover, the Protection Status field of the domain name changes to Unprotected.
    • Bypass
      1. In the row containing the target domain name, click Bypass WAF in the Operation column.
      2. In the Bypass WAF dialog box, check the impact of switching to the bypass mode, obtain and enter the verification code, and click OK.
        After the switchover, the Protection Status field of the domain name changes to Bypassed.
