Updated on 2025-10-28 GMT+08:00
VPC Endpoint Monitoring Metrics
This topic describes VPC Endpoint namespaces, the metrics that can be monitored by Cloud Eye, and dimensions of these metrics. You can log in to the Cloud Eye console or call Cloud Eye APIs to query the VPC endpoint metrics and alarms.
Namespace
SYS.VPCEP
VPC Endpoint Metrics
Table 1 VPC endpoint metrics
Metric ID
Name
Value Range
Unit
Conversion Rule
Dimension
Monitoring Interval
vpcep_rx_bps
Inbound Bandwidth
Inbound bandwidth of the VPC endpoint
≥ 0
bit/s
1024 (IEC)
ep_instance_id
60s
vpcep_tx_bps
Outbound Bandwidth
Outbound bandwidth of the VPC endpoint
≥ 0
bit/s
1024 (IEC)
60s
vpcep_bps
Inbound and Outbound Bandwidth
Inbound and outbound bandwidth of the VPC endpoint
≥ 0
bit/s
1024 (IEC)
60s
vpcep_rx_pps
Inbound PPS
Inbound PPS of the VPC endpoint
≥ 0
packets/s
N/A
60s
vpcep_tx_pps
Outbound PPS
Outbound PPS of the VPC endpoint
≥ 0
packets/s
N/A
60s
vpcep_pps
Inbound and Outbound PPS
Inbound and outbound PPS of the VPC endpoint
≥ 0
packets/s
N/A
60s
vpcep_rx_byte
Inbound Traffic
Inbound traffic of the VPC endpoint
≥ 0
byte
1024 (IEC)
60s
vpcep_tx_byte
Outbound Traffic
Outbound traffic of the VPC endpoint
≥ 0
byte
1024 (IEC)
60s
vpcep_drop_num
Packets Dropped
Number of packets dropped by the VPC endpoint
≥ 0
packets
N/A
60s
vpcep_connections
Connections
Number of current connections established between the VPC endpoint and the VPC endpoint service it connects to
≥ 0
count
N/A
60s
vpcep_act_connections
Active Connections
Number of active connections established between the VPC endpoint and the VPC endpoint service it connects to
≥ 0
count
N/A
60s
vpcep_from_client_rst_num
RST Packets from Clients
Number of RST packets sent from clients to servers
≥ 0
packets
N/A
60s
vpcep_from_server_rst_num
RST Packets from Servers
Number of RST packets sent from servers to clients
≥ 0
packets
N/A
60s
vpcep_to_client_rst_num
RST Packets from VPCEP to Clients
Number of RST packets sent from VPCEP to clients
≥ 0
packets
N/A
60s
vpcep_to_server_rst_num
RST Packets from VPCEP to Servers
Number of RST packets sent from VPCEP to servers
≥ 0
packets
N/A
60s
VPC Endpoint Service Monitoring Metrics
Table 2 VPC endpoint service monitoring metrics
Metric ID
Name
Value Range
Unit
Conversion Rule
Dimension
Monitoring Interval
vpcep_eps_rx_bps
Inbound Bandwidth
Inbound bandwidth of the VPC endpoint service
≥ 0
bit/s
1024 (IEC)
eps_id
60s
vpcep_eps_tx_bps
Outbound Bandwidth
Outbound bandwidth of the VPC endpoint service
≥ 0
bit/s
1024 (IEC)
60s
vpcep_eps_bps
Inbound and outbound bandwidth of the VPC endpoint service
≥ 0
bit/s
1024 (IEC)
60s
vpcep_eps_rx_pps
Inbound PPS
Inbound PPS of the VPC endpoint service
≥ 0
packets/s
N/A
60s
vpcep_eps_tx_pps
Outbound PPS
Outbound PPS of the VPC endpoint service
≥ 0
packets/s
N/A
60s
vpcep_eps_pps
Inbound and outbound PPS of the VPC endpoint service
≥ 0
packets/s
N/A
60s
vpcep_eps_rx_byte
Inbound Traffic
Inbound traffic of the VPC endpoint service
≥ 0
byte
1024 (IEC)
60s
vpcep_eps_tx_byte
Outbound Traffic
Outbound traffic of the VPC endpoint service
≥ 0
byte
1024 (IEC)
60s
vpcep_eps_drop_num
Packets Dropped
Number of packets dropped by the VPC endpoint service
≥ 0
packets
N/A
60s
vpcep_eps_connections
Connections
Number of current connections established between the VPC endpoint service and all VPC endpoints connected to it
≥ 0
count
N/A
60s
vpcep_eps_act_connections
Active Connections
Number of active connections established between the VPC endpoint service and all VPC endpoints connected to it
≥ 0
count
N/A
60s
vpcep_eps_from_client_rst_num
≥ 0
packets
N/A
60s
vpcep_eps_from_server_rst_num
≥ 0
packets
N/A
60s
vpcep_eps_to_client_rst_num
≥ 0
packets
N/A
60s
vpcep_eps_to_server_rst_num
≥ 0
packets
N/A
60s
Dimension
Key
Value
ep_instance_id
VPC endpoint ID.
You can obtain the VPC endpoint ID by referring to Querying VPC Endpoints.
The value of parameter id is the VPC endpoint ID.
eps_id
VPC endpoint service ID.
You can obtain the VPC endpoint service ID by referring to Querying VPC Endpoint Services.
The value of parameter id is the VPC endpoint service ID.
