VPC Endpoint Service Overview
Overview
A VPC endpoint service is a cloud service or a private service that can be accessed through a VPC endpoint.
- Gateway VPC endpoint services are configured by the system only for cloud services.
- Interface VPC endpoint services can be configured for cloud services or private services. Cloud services are configured as interface VPC endpoint services by the system by default. However, private services must be configured as interface VPC endpoint services by users.
Supported cloud services vary by region. For details, see the services that can be configured on the management console.
In some regions, you can select OBS as a gateway VPC endpoint service on the console.
To select OBS as a gateway VPC endpoint service in other regions, you need to search for it by name. To obtain its name, you can submit a service ticket or contact the OBS O&M engineers.
Service Provider
As the service owner, a service provider uses Huawei Cloud resources to create and provide VPC endpoint services for service users. A service user accesses a VPC endpoint service by connecting to the VPC endpoint associated with the VPC endpoint service.
- VPC endpoint service resources: Huawei Cloud services and user private services that can be used as VPC endpoint service resources. For details, see Gateway VPC Endpoint Services and Interface VPC Endpoint Services.
- VPC endpoint service name: A VPC endpoint service name uniquely identifies a VPC endpoint service. When creating a VPC endpoint, a service user can use this name to uniquely identify the service to be connected.
- VPC endpoint service whitelist: A VPC endpoint service is not visible to all service users by default. If a service provider wants VPCs of other Huawei Cloud accounts to access the VPC endpoint service, the service provider needs to add the Huawei Cloud accounts of the service users to the whitelist of the VPC endpoint service. For details, see Adding a Whitelist Record.
- VPC endpoint service status: Table 1 describes the VPC endpoint service statuses and the meaning of each status.
Table 1 Statuses of a VPC endpoint service Status
Creating
The VPC endpoint service is being created.
Available
The VPC endpoint service is created and can accept a VPC endpoint.
Failed
The VPC endpoint service failed to be created.
Deleting
The VPC endpoint service is being deleted.
Deleted
The VPC endpoint service has been deleted.
Related Operations
| Operation | Description | Constraints |
| Describes how to configure a private service as a VPC endpoint service. |
| Describes how to check and delete a VPC endpoint service. |
| Describes how to set connection approval of a VPC endpoint service to determine whether to allow a VPC endpoint to connect to the VPC endpoint service. | You can specify whether to allow a VPC endpoint to connect to a VPC endpoint service only when connection approval is enabled. | |
| Describes how to manage whitelist records of a VPC endpoint service to control cross-account access between a VPC endpoint and a VPC endpoint service. |
| Describes how to view the port mapping between a VPC endpoint and a VPC endpoint service, including the supported protocol, service port, and terminal port. |
| Describes how to query, add, edit, and delete tags of a VPC endpoint service. | You can add up to 20 tags to each VPC endpoint service. |
