Managing Port Mappings of a VPC Endpoint Service
After a VPC endpoint service is created, you can add, modify, and view its port mappings.
You can view the protocol, service port, and terminal port.
Adding a Port Mapping
- Go to the VPC endpoint service list page.
Modifying a Port Mapping
- In the VPC endpoint service list, locate the VPC endpoint service and click its name.
- Click the Port Mapping tab, locate the port mapping, and click Modify in the Operation column.
Configure the parameters.
Figure 2 Modify Port Mapping
- Click OK.
Deleting a Port Mapping
If a VPC endpoint service has only one port mapping, this port mapping cannot be deleted.
- Click the Port Mapping tab, locate the port mapping, and click Delete in the Operation column.
Figure 3 Deleting a port mapping
- Confirm the information and click OK.
