Help Center/
VPC Endpoint/
User Guide/
VPC Endpoint Services/
Managing Connections of a VPC Endpoint Service
Updated on 2025-11-12 GMT+08:00
To connect a VPC endpoint to a VPC endpoint service that has connection approval enabled, obtain the approval from the owner of the VPC endpoint service.
This section describes how to accept or reject a connection from a VPC endpoint.
- There is a VPC endpoint available for connecting to the target VPC endpoint service.
- Connection Approval of the VPC endpoint service is enabled.
- Go to the VPC endpoint service list page.
- In the VPC endpoint service list, locate the VPC endpoint service and click its name.
- Select the Connection Management tab.
Figure 1 Connection Management
- Accept or reject connection from a VPC endpoint in the list based on service requirements.
- If you click Accept, the VPC endpoint can connect to the VPC endpoint service.
- If you click Reject, the VPC endpoint cannot connect to the VPC endpoint service.
Parent topic: VPC Endpoint Services
