- What's New
- Function Overview
- Billing
- Getting Started
User Guide
VPC Endpoint Services
- VPC Endpoint Service Overview
- Creating a VPC Endpoint Service
- Viewing a VPC Endpoint Service
- Deleting a VPC Endpoint Service
- Managing Connections of a VPC Endpoint Service
- Managing Whitelist Records of a VPC Endpoint Service
- Managing Port Mappings of a VPC Endpoint Service
- Managing Tags of a VPC Endpoint Service
- VPC Endpoints
- Accessing OBS
- Using Cloud Eye to Monitor VPC Endpoints
- Using CTS to Audit VPC Endpoints
- Permissions Management
- Quotas
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Version Management
- Querying VPC Endpoint Services
- Querying Details of a VPC Endpoint Service
- Modifying a VPC Endpoint Service
- Querying Connections to a VPC Endpoint Service
- Accepting or Rejecting a VPC Endpoint
- Querying Whitelist Records of a VPC Endpoint Service
- Batch Adding or Deleting Whitelist Records of a VPC Endpoint Service
- Querying Public VPC Endpoint Services
- Querying Basic Information About a VPC Endpoint Service
- Changing the Name of a VPC Endpoint Service
- Updating Descriptions of VPC Endpoint Connections
- Batch Adding Whitelist Records of a VPC Endpoint Service
- Batch Deleting Whitelist Records of a VPC Endpoint Service
- Updating the Description of a Whitelist Record of a VPC Endpoint Service
- VPC Endpoints
- Resource Quotas
- Tags
- Application Examples
- Appendix
- SDK Reference
- FAQs
More Documents
- Getting Started
- Viewing Summary of a VPC Endpoint Service
- Viewing Port Mappings of a VPC Endpoint Service
- VPC Endpoints
- Permission Management
- FAQs
- Change History
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
APIs for Managing VPC Endpoint Services
- Querying Connections of a VPC Endpoint Service
- Querying the Whitelist Records of a VPC Endpoint Service
- APIs for Managing VPC Endpoints
- Resource Quota
- Tag Function
- Appendix
- Change History
User Guide (Paris Region)
Getting Started
- Operation Guide
- Configuring a VPC Endpoint for Communications Across VPCs of the Same Domain
- Configuring a VPC Endpoint for Communications Across VPCs of Different Domains
- Configuring a VPC Endpoint for Accessing the Private IP Address of OBS over Private Networks
- Configuring a VPC Endpoint for Accessing the Public IP Address of OBS over Public Networks
- Viewing the Summary of a VPC Endpoint Service
- VPC Endpoints
- Quotas
- FAQ
- Change History
API Reference (Paris Region)
- Before You Start
- API Overview
- Calling APIs
APIs
- Querying Details About a VPC Endpoint Service
- Resource Quota
- Tag Function
- Appendix
- Change History
- Getting Started
- VPC Endpoints
- Quotas
- FAQ
- Change History
- Before You Start
- API Overview
- Calling APIs
APIs
- Resource Quota
- Tag Function
- Appendix
- Change History
- User Guide (Ankara Region)
API Reference (Ankara Region)
- Before You Start
- API Overview
- Calling APIs
APIs
- Resource Quota
- Appendix
- Change History
On this page
Show all
Viewing Metrics
You can view details of VPC Endpoint metrics on the Cloud Eye console.
You can perform the same steps as described in the following to view the metrics of a VPC endpoint service or a VPC endpoint.
- Hover on
to display Service List and choose Management & Governance > Cloud Eye.
Figure 1 Cloud Eye - In the navigation pane on the left, choose Cloud Service Monitoring > VPC Endpoint.
The VPC endpoint service tab is displayed.Figure 2 VPC Endpoint
- Locate the VPC endpoint service and click View Metric in the Operation column to view its metrics.
You can view data of the last 1, 3, 12, or 24 hours, or data of the last 7 days.
Parent topic: Using Cloud Eye to Monitor VPC Endpoints
