- What's New
- Function Overview
- Billing
- Getting Started
User Guide
VPC Endpoint Services
- VPC Endpoint Service Overview
- Creating a VPC Endpoint Service
- Viewing a VPC Endpoint Service
- Deleting a VPC Endpoint Service
- Managing Connections of a VPC Endpoint Service
- Managing Whitelist Records of a VPC Endpoint Service
- Managing Port Mappings of a VPC Endpoint Service
- Managing Tags of a VPC Endpoint Service
- VPC Endpoints
- Accessing OBS
- Using Cloud Eye to Monitor VPC Endpoints
- Using CTS to Audit VPC Endpoints
- Permissions Management
- Quotas
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Version Management
- Querying VPC Endpoint Services
- Querying Details of a VPC Endpoint Service
- Modifying a VPC Endpoint Service
- Querying Connections to a VPC Endpoint Service
- Accepting or Rejecting a VPC Endpoint
- Querying Whitelist Records of a VPC Endpoint Service
- Batch Adding or Deleting Whitelist Records of a VPC Endpoint Service
- Querying Public VPC Endpoint Services
- Querying Basic Information About a VPC Endpoint Service
- Changing the Name of a VPC Endpoint Service
- Updating Descriptions of VPC Endpoint Connections
- Batch Adding Whitelist Records of a VPC Endpoint Service
- Batch Deleting Whitelist Records of a VPC Endpoint Service
- Updating the Description of a Whitelist Record of a VPC Endpoint Service
- VPC Endpoints
- Resource Quotas
- Tags
- Application Examples
- Appendix
- SDK Reference
- FAQs
More Documents
- Getting Started
- Viewing Summary of a VPC Endpoint Service
- Viewing Port Mappings of a VPC Endpoint Service
- VPC Endpoints
- Permission Management
- FAQs
- Change History
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
APIs for Managing VPC Endpoint Services
- Querying Connections of a VPC Endpoint Service
- Querying the Whitelist Records of a VPC Endpoint Service
- APIs for Managing VPC Endpoints
- Resource Quota
- Tag Function
- Appendix
- Change History
User Guide (Paris Region)
Getting Started
- Operation Guide
- Configuring a VPC Endpoint for Communications Across VPCs of the Same Domain
- Configuring a VPC Endpoint for Communications Across VPCs of Different Domains
- Configuring a VPC Endpoint for Accessing the Private IP Address of OBS over Private Networks
- Configuring a VPC Endpoint for Accessing the Public IP Address of OBS over Public Networks
- Viewing the Summary of a VPC Endpoint Service
- VPC Endpoints
- Quotas
- FAQ
- Change History
API Reference (Paris Region)
- Before You Start
- API Overview
- Calling APIs
APIs
- Querying Details About a VPC Endpoint Service
- Resource Quota
- Tag Function
- Appendix
- Change History
- Getting Started
- VPC Endpoints
- Quotas
- FAQ
- Change History
- Before You Start
- API Overview
- Calling APIs
APIs
- Resource Quota
- Tag Function
- Appendix
- Change History
- User Guide (Ankara Region)
API Reference (Ankara Region)
- Before You Start
- API Overview
- Calling APIs
APIs
- Resource Quota
- Appendix
- Change History
Show all
Supported Metrics
This topic describes VPC Endpoint namespaces, the metrics that can be monitored by Cloud Eye, and dimensions of these metrics. You can log in to the Cloud Eye console or call Cloud Eye APIs to query the VPC endpoint metrics and alarms.
Namespace
SYS.VPCEP
Metrics
Metric ID |
Name |
Description |
Value Range |
Monitored Object |
Monitoring Period |
vpcep_rx_bps |
Inbound Bandwidth |
Inbound bandwidth of the VPC endpoint Unit: bit/s |
≥ 0 |
VPC endpoint |
60s |
vpcep_tx_bps |
Outbound Bandwidth |
Outbound bandwidth of the VPC endpoint Unit: bit/s |
≥ 0 |
60s |
vpcep_bps |
Inbound and Outbound Bandwidth |
Inbound and outbound bandwidth of the VPC endpoint Unit: bit/s |
≥ 0 |
60s |
vpcep_rx_pps |
Inbound PPS |
Inbound PPS of the VPC endpoint Unit: Packets/s |
≥ 0 |
60s |
vpcep_tx_pps |
Outbound PPS |
Outbound PPS of the VPC endpoint Unit: Packets/s |
≥ 0 |
60s |
vpcep_pps |
Inbound and Outbound PPS |
Inbound and outbound PPS of the VPC endpoint Unit: Packets/s |
≥ 0 |
60s |
vpcep_rx_byte |
Inbound Traffic |
Inbound traffic of the VPC endpoint Unit: bytes |
≥ 0 |
60s |
vpcep_tx_byte |
Outbound Traffic |
Outbound traffic of the VPC endpoint Unit: bytes |
≥ 0 |
60s |
vpcep_drop_num |
Packets Dropped |
Number of packets dropped by the VPC endpoint Unit: Packets |
≥ 0 |
60s |
vpcep_connections |
Connections |
Number of current connections established between the VPC endpoint and the VPC endpoint service it connects to Unit: Count |
≥ 0 |
60s |
vpcep_act_connections |
Active Connections |
Number of active connections established between the VPC endpoint and the VPC endpoint service it connects to Unit: Count |
≥ 0 |
60s |
vpcep_eps_rx_bps |
Inbound Bandwidth |
Inbound bandwidth of the VPC endpoint service Unit: bit/s |
≥ 0 |
VPC endpoint service |
60s |
vpcep_eps_tx_bps |
Outbound bandwidth of the VPC endpoint service Unit: bit/s |
≥ 0 |
60s |
vpcep_eps_bps |
Inbound and outbound bandwidth of the VPC endpoint service Unit: bit/s |
≥ 0 |
60s |
vpcep_eps_rx_pps |
Inbound PPS |
Inbound PPS of the VPC endpoint service Unit: Packets/s |
≥ 0 |
60s |
vpcep_eps_tx_pps |
Outbound PPS |
Outbound PPS of the VPC endpoint service Unit: Packets/s |
≥ 0 |
60s |
vpcep_eps_pps |
Inbound and outbound PPS of the VPC endpoint service Unit: Packets/s |
≥ 0 |
60s |
vpcep_eps_rx_byte |
Inbound Traffic |
Inbound traffic of the VPC endpoint service Unit: bytes |
≥ 0 |
60s |
vpcep_eps_tx_byte |
Outbound Traffic |
Outbound traffic of the VPC endpoint service Unit: bytes |
≥ 0 |
60s |
vpcep_eps_drop_num |
Packets Dropped |
Number of packets dropped by the VPC endpoint service Unit: Packets |
≥ 0 |
60s |
vpcep_eps_connections |
Connections |
Number of current connections established between the VPC endpoint service and all VPC endpoints connect to it Unit: Count |
≥ 0 |
60s |
vpcep_eps_act_connections |
Number of active connections established between the VPC endpoint service and all VPC endpoints connect to it Unit: Count |
≥ 0 |
60s |
Dimension
Key |
Value |
ep_instance_id |
VPC endpoint |
eps_id |
