Modifying a Network ACL Rule
Updated on 2025-01-17 GMT+08:00
If a network ACL rule no longer meets your requirements, you can modify the port, protocol, and source/destination it.
Modifying rules may affect how and where traffic is directed. Be careful with this operation as it may interrupt services.
Notes and Constraints
Default network ACL rules cannot be modified or deleted.
  1. Click in the upper left corner and select the desired region and project.
  2. Click in the upper left corner and choose Networking > Virtual Private Cloud.
    The Virtual Private Cloud page is displayed.
  3. In the navigation pane on the left, choose Access Control > Network ACLs.
    The network ACL list is displayed.
  4. In the network ACL list, locate the target network ACL and click its name.
    The network ACL summary page is displayed.
  5. Click the Inbound Rules or Outbound Rules tab, locate the target rule, click Modify in the Operation column, and modify parameters based on Table 1.
    Table 1 Parameter descriptions
    Example Value
    Type
    Network ACL type. There are two options:
    • IPv4
    • IPv6
    IPv4
    Action
    The action for the network ACL rule. There are two options:
    • Allow: allows matched traffic in and out of a subnet.
    • Deny: denies matched traffic in and out of a subnet.
    Allow
    Protocol
    The protocol supported by the network ACL to match traffic. The value can be TCP, UDP, or ICMP.
    TCP
    Source
    The source from which the traffic is allowed or denied. The source can be:
    • IP address
      • Single IP address: IP address/mask
        Example IPv4 address: 192.168.10.10/32
        Example IPv6 address: 2002:50::44/128
      • IP address range in CIDR notation: IP address/mask
        Example IPv4 address range: 192.168.52.0/24
        Example IPv6 address range: 2407:c080:802:469::/64
      • All IP addresses
        0.0.0.0/0 represents all IPv4 addresses.
        ::/0 represents all IPv6 addresses.
    • IP address group: The source is an IP address group. An IP address group is a collection of one or more IP addresses. You can select an available IP address group from the drop-down list. An IP address group can help you manage IP address ranges and IP addresses with same security requirements in an easier way.
      Either the source or the destination of a network ACL rule can use the IP address group. For example, if the source uses an IP address group, the destination address cannot use an IP address group.
      If no IP address groups are available, create one by referring to Creating an IP Address Group.
    192.168.0.0/24
    Source Port Range
    The source ports or port ranges used to match traffic. The value ranges from 1 to 65535.
    Enter ports in the following format:
    • Individual port: Enter a port, such as 22.
    • Consecutive ports: Enter a port range, such as 22-30.
    • Non-consecutive ports: Enter ports and port ranges, such as 22,24-30. You can enter a maximum of 20 ports and port ranges. Each port range must be unique.
    • All ports: Leave it empty or enter 1-65535.
    22-30
    Destination
    The destination to which the traffic is allowed or denied. The destination can be:
    • IP address
      • All IP addresses
    • IP address group: The destination is an IP address group. An IP address group is a collection of one or more IP addresses. You can select an available IP address group from the drop-down list. An IP address group can help you manage IP address ranges and IP addresses with same security requirements in an easier way.
    0.0.0.0/0
    Destination Port Range
    The destination ports or port ranges used to match traffic. The value ranges from 1 to 65535.
    • Non-consecutive ports: Enter ports and port ranges, such as 22,23-30. You can enter a maximum of 20 ports and port ranges. Each port range must be unique.
    22-30
    Supplementary information about the network ACL rule. This parameter is optional.
    The description can contain a maximum of 255 characters and cannot contain angle brackets (< or >).
    N/A
  6. Click OK.
