Media Asset Parsing Message Body
Sample Media Asset Parsing Message
"event_type": "parseComplete",
"parse_info": {
"status": "SUCCEED",
"asset_id": "d501e8fd23f550a432f2c528c3823fd8",
"meta_data": {
"play_type": 0,
"pack_type": "MP4",
"codec": "H.264",
"audio_codec": "AAC",
"audio_bit_rate": 126,
"duration": 53,
"video_size": 13454959,
"width": 960,
"hight": 540,
"bit_rate": 1939,
"frame_rate": 25,
"audio_channels": 2,
"sample": 48000
"original_url": "https://103.huaweicloud.com/asset/d501e8fd23f550a432f2c528c3823fd8/3cb5b599a92c683c80306f7b4a2dd427.mp4"
} Message Body Description
| Parameter | Description |
| asset_id | ID of the parsed media asset |
| status | Event status
| fileAddr | Address of the OBS bucket where the source media file is. This parameter is used only when the source file is in the tenant bucket. |
| original_url | URL of the media asset. |
| meta_data | Media data of the media asset. |
| error_code | Error code. This parameter is used only when status is FAILED. |
| error_msg | Error description. This parameter is used only when status is FAILED. |
