Viewing Task Details
On the Task List page, you can view the status, video source, algorithm service, vendor, and creation time of each task. To view specified tasks, you need to perform fuzzy search by task name or video source name, or filter tasks by task status and algorithm service. Then, you can sort the tasks by creation time in ascending or descending order.
You can click the name of a task to view the task details, including the algorithm configuration template used by the task and the task output configuration.
If a task is in the Running or Succeeded status, the task status is normal. After a task succeeds, you can view the task result based on the output mode and path selected during the task creation. For details, see Obtaining Task Results.
There are 19 task statuses, as shown in Table 1.
Status |
Description |
Succeeded |
The task is executed. |
Stopped |
The task is stopped. |
Deleted |
The task has been deleted. |
Running |
The task is running properly. |
Scheduling |
The task is being scheduled. |
Pending |
The task is queuing and awaiting resource allocation. |
Failed |
The task failed. |
Create Failed |
Creating the task failed. |
Abnormal |
The task is abnormal. |
Deleting |
The task is being deleted. |
Stopping |
The task is being stopped. |
Recovering |
The task is being recovered. |
Starting |
The task is being started. |
Updating |
The task is being updated. |
Start Failed |
Starting the task failed. |
Freezing |
The task is being frozen because you are in arrears. |
Frozen |
The task has been deleted on the edge node. However, it will be restarted after your account is topped up in the retention period. |
Creating |
The task is being created. |
Lack of resources |
Resources for the task are insufficient. |
