Deploying an Algorithm Service
Updated on 2024-11-12 GMT+08:00
Viewing the Algorithm Service List
After purchasing an algorithm service package, you can choose Algorithm Center > Algorithm Service to view the list of available algorithm services.
Algorithm services can be classified into Huawei-developed cloud algorithms, Huawei-developed edge algorithms, non-Huawei-developed cloud algorithms, and non-Huawei-developed edge algorithms by scenario and source. A Huawei-developed cloud algorithm can be directly used for video analysis tasks without the need to deploy it.
Huawei-developed edge algorithms and non-Huawei-developed cloud and edge algorithms must be deployed before being used. An algorithm can be used only when its deployment status is Running.
  1. On the Algorithm Service page, locate the target algorithm service and click Deploy in the Operation column.
  2. Set parameters according to Table 1.
    Table 1 Parameters for deploying an algorithm
    Channels
    Maximum number of channels required. The system will allocate and create enough algorithm resources in the backend to run your tasks.
    Resource Pool
    Select the resource pool used for the deployment.
    Service Startup Parameters
    Parameters for this deployment. The startup parameters vary depending on the algorithm service. For details about the parameter functions, contact the algorithm developer.
When the deployment status is Running or Deploying, you can click Stop Deployment to stop the deployment.
