Getting Started
Updated on 2024-11-12 GMT+08:00
Process of Using an Edge Algorithm
Table 1 Process
Task
Subtask
Instruction
Preparing an edge algorithm
Creating an edge resource pool
An edge resource pool is a group of edge nodes used to process analysis tasks. Before creating an analysis task, create an edge resource pool.
Creating an Edge Resource Pool
Purchasing an algorithm package
Purchase an edge algorithm package based on service requirements.
Purchasing an Algorithm Package
Deploying an algorithm service
Before using an edge algorithm, deploy it in an edge resource pool.
Deploying an Algorithm Service
Setting input and output modes
Adding video sources
To use an algorithm service on VIAS, add video sources, and use the video sources to create an analysis task that the algorithm service can analyze and output results.
Edge algorithms support three video source origins: camera, RESTful, and VCN.
Adding a Video Source
Choosing an output channel
Prepare channels before outputting task analysis results to DIS channels or webhook URLs.
Choosing an Output Channel
Creating an analysis task
Creating a task
To create a task, specify a video source and an algorithm service, configure the algorithm parameters and task execution plan, and select the output mode.
Creating a Task
Viewing the analysis result
Viewing the task status
After a task is created, check its status. After it succeeds, obtain the task analysis result.
Viewing Task Details
Obtaining task results
Obtain the task analysis result based on the output mode.
Obtaining Task Results
Process of Using a Cloud Algorithm
Table 2 Process
Task
Sub Task
Instruction
Cloud algorithms support video source origins including OBS, URL, RESTful, VCN, and IVM.
Prepare channels before outputting task analysis results to DIS channels or webhook URLs. To export results to OBS, you must enable OBS beforehand.
Preparing a cloud algorithm
Creating a cloud resource pool
To use a cloud algorithm that is not developed by Huawei, purchase a resource pool to deploy the algorithm.
N/A
Purchase a cloud algorithm package based on service requirements.
To use a cloud algorithm that is not developed by Huawei, deploy the algorithm.
Creating a task
Creating a Task
