- Getting Started
- User Guide
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
API Description
VBS Backups
- Creating a VBS Backup
- Deleting a VBS Backup (Deprecated)
- Restoring a Disk Using a VBS Backup
- Creating a VBS Backup (Native OpenStack API) (Deprecated)
- Querying Summary Information About VBS Backups (Native OpenStack API) (Deprecated)
- Querying Details About VBS Backups (Native OpenStack API) (Deprecated)
- Querying Details About a VBS Backup (Native OpenStack API) (Deprecated)
- Querying the Job Status
- Deleting a VBS Backup (Native OpenStack API) (Deprecated)
- Restoring a Disk Using a VBS Backup (Native OpenStack API) (Deprecated)
- Sharing a Backup
- Canceling Sharing of a Backup
- Querying Backup Sharings
- Counting Backup Sharings
- Querying Details About a Backup Sharing
Backup Policies
- Creating a Backup Policy
- Querying Backup Policies
- Modifying a Backup Policy
- Deleting a Backup Policy
- Associating Resources with a Backup Policy
- Disassociating Resources from a Backup Policy
- Executing a Backup Policy At Once
- Enabling or Disabling a Backup Policy
- Querying Backup Jobs Triggered by a Backup Policy
- Adding a Tag to a Backup Policy
- Removing a Tag from a Backup Policy
- Querying All Backup Policy Tags
- Querying Tags of a Backup Policy
- Batch Updating or Removing Tags of a Backup Policy
- Querying Backup Policies by Tag
VBS Backups
- Appendix
- What Is Volume Backup Service?
- What Is a Backup Policy?
- What Are the Differences Between Backup and Disaster Recovery?
- How Do I Purchase and Renew VBS?
- What Are the Differences Between CSBS and VBS?
- Does VBS Support Simultaneous Backup of All EVS Disks on a Server?
- Do I Need to Stop the Server Before Backing Up EVS Disks on a Server Using VBS?
- How Long Does VBS Take to Back Up an EVS Disk?
- Does VBS Support Cross-Region Backup and Restoration?
- Do I Need to Stop the Server Before Restoring EVS Disk Data with a VBS Backup?
- What Is the Charging Mode of EVS Disks Created with a VBS Backup?
- Why Are CSBS Backups Displayed on the VBS Backup Page?
- Can a VBS Backup of a System Disk Be Used to Restore the System Disk of an ECS?
- Can I Use a VBS Backup to Restore an EVS Disk Whose Capacity Has Been Expanded?
- Is There a Quota Limit on the Number of Backups?
- What Can I Do In Case of Exceptions in VBS?
- Why Add Tags to a VBS Backup or Backup Policy?
- Does Backup Can Be Performed Several Times a Day?
- Can a Disk Only Be Associated With One Policy?
- What Are Full Backup and Incremental Backup?
- What Are the Differences Between Backups and Snapshots?
- Why Is the Remaining Space Not Changed After a Backup Is Deleted?
- Why Is the Disk Space Usage Displayed in the File System Different from the Backup Size?
- Why Does the Retention Rule Not Take Effect After Being Modified?
- How Do I Disable Automatic Backup?
- Videos
- Glossary
More Documents
User Guide (Paris)
- Getting Started
- Operation Guide
- Troubleshooting Cases
- Change History
API Reference (Paris)
- Before You Start
- API Overview
- Calling APIs
- Getting Started
API Description
VBS Backups
Backup Policies
VBS Backups
- Appendix
- Change History
User Guide (Paris)
Viewing VBS Traces
CTS records operations of VBS resources, facilitating query, audit, and backtracking.
You have enabled CTS and the tracker is running properly. For details about how to enable CTS, see section "Enabling CTS" in the Cloud Trace Service User Guide.
Key Operations Recorded by CTS
Operation |
Resource Type |
Trace |
Creating a backup |
vbs |
bksCreateBackup |
Deleting a backup |
vbs |
bksDeleteBackup |
Restoring a backup |
vbs |
bksRestoreBackup |
Associating a backup policy |
autobackup |
addPolicyResource |
Disassociating a backup policy |
autobackup |
deletePolicyResource |
Executing a backup policy |
autobackup |
actionPolicy |
Creating a backup policy |
autobackup |
createPolicy |
Deleting a backup policy |
autobackup |
deletePolicy |
Modifying a backup policy |
autobackup |
modifyPolicy |
Creating a backup scheduled by a backup policy |
autobackup |
scheduleCreateBackup |
Automatically deleting a backup scheduled by a backup policy |
autobackup |
scheduleDeleteBackup |
Batch adding or modifying tags of a backup policy |
autobackup |
batchAddPolicyTag |
Batch deleting tags of a backup policy |
autobackup |
batchDeletePolicyTag |
Viewing CTS Traces
- In the upper left corner of the page, click
and select the desired region and project.
- Click Service List. Under Management & Governance, click Cloud Trace Service.
- In the navigation pane on the left, choose Trace List.
- On the trace list page, click Filter. In the displayed box, specify Trace Source, Resource Type, and Search By, and click Query to query the specified traces.
For details about other operations, see section "Querying Real-Time Traces" in the Cloud Trace Service User Guide.
Disabling or Enabling a Tracker
This section describes how to disable an existing tracker on the CTS console. After the tracker is disabled, the system will stop recording operations, but you can still view existing operation records.
- Click Tracker in the left pane.
- Click Disable on the right of the tracker information.
- Click OK.
- After the tracker is disabled, its status changes from Disable to Enable. To enable the tracker again, click Enable and then click OK. The system will start recording operations again.
