- Getting Started
- User Guide
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
API Description
VBS Backups
- Creating a VBS Backup
- Deleting a VBS Backup (Deprecated)
- Restoring a Disk Using a VBS Backup
- Creating a VBS Backup (Native OpenStack API) (Deprecated)
- Querying Summary Information About VBS Backups (Native OpenStack API) (Deprecated)
- Querying Details About VBS Backups (Native OpenStack API) (Deprecated)
- Querying Details About a VBS Backup (Native OpenStack API) (Deprecated)
- Querying the Job Status
- Deleting a VBS Backup (Native OpenStack API) (Deprecated)
- Restoring a Disk Using a VBS Backup (Native OpenStack API) (Deprecated)
- Sharing a Backup
- Canceling Sharing of a Backup
- Querying Backup Sharings
- Counting Backup Sharings
- Querying Details About a Backup Sharing
Backup Policies
- Creating a Backup Policy
- Querying Backup Policies
- Modifying a Backup Policy
- Deleting a Backup Policy
- Associating Resources with a Backup Policy
- Disassociating Resources from a Backup Policy
- Executing a Backup Policy At Once
- Enabling or Disabling a Backup Policy
- Querying Backup Jobs Triggered by a Backup Policy
- Adding a Tag to a Backup Policy
- Removing a Tag from a Backup Policy
- Querying All Backup Policy Tags
- Querying Tags of a Backup Policy
- Batch Updating or Removing Tags of a Backup Policy
- Querying Backup Policies by Tag
VBS Backups
- Appendix
- What Is Volume Backup Service?
- What Is a Backup Policy?
- What Are the Differences Between Backup and Disaster Recovery?
- How Do I Purchase and Renew VBS?
- What Are the Differences Between CSBS and VBS?
- Does VBS Support Simultaneous Backup of All EVS Disks on a Server?
- Do I Need to Stop the Server Before Backing Up EVS Disks on a Server Using VBS?
- How Long Does VBS Take to Back Up an EVS Disk?
- Does VBS Support Cross-Region Backup and Restoration?
- Do I Need to Stop the Server Before Restoring EVS Disk Data with a VBS Backup?
- What Is the Charging Mode of EVS Disks Created with a VBS Backup?
- Why Are CSBS Backups Displayed on the VBS Backup Page?
- Can a VBS Backup of a System Disk Be Used to Restore the System Disk of an ECS?
- Can I Use a VBS Backup to Restore an EVS Disk Whose Capacity Has Been Expanded?
- Is There a Quota Limit on the Number of Backups?
- What Can I Do In Case of Exceptions in VBS?
- Why Add Tags to a VBS Backup or Backup Policy?
- Does Backup Can Be Performed Several Times a Day?
- Can a Disk Only Be Associated With One Policy?
- What Are Full Backup and Incremental Backup?
- What Are the Differences Between Backups and Snapshots?
- Why Is the Remaining Space Not Changed After a Backup Is Deleted?
- Why Is the Disk Space Usage Displayed in the File System Different from the Backup Size?
- Why Does the Retention Rule Not Take Effect After Being Modified?
- How Do I Disable Automatic Backup?
- Videos
- Glossary
More Documents
User Guide (Paris)
- Getting Started
- Operation Guide
- Troubleshooting Cases
- Change History
API Reference (Paris)
- Before You Start
- API Overview
- Calling APIs
- Getting Started
API Description
VBS Backups
Backup Policies
VBS Backups
- Appendix
- Change History
User Guide (Paris)
Show all
(Optional) Other Operations with Backup Policies
You can edit, enable, execute, and delete backup policies.
- Click
. Under Storage, click Volume Backup Service.
- On the Volume Backup Service page, click Policies to go to the Policies tab page.
- Editing a backup policy
- Enabling a backup policy
In the Operation column of the backup policy you want to enable, click Edit. On the displayed page, click
to turn on this option.
Alternatively, you can choose More > Enable in the Operation column for the backup policy.
After the backup policy is successfully enabled, and the system will automatically execute periodic backup jobs based on policy settings.
- Executing a backup policy
Before performing this operation, check whether EVS disks are associated with the backup policy. If not, associate EVS disks with the backup policy first.
- When the backup policy is associated with EVS disks, select the backup policy, and choose More > Execute in the Operation column.
A confirmation dialog box is displayed. See Figure 2.
- Confirm the backup policy parameter information and click OK.
On the Backup Jobs panel, view all the backup jobs executed based on this backup policy.
- Deleting a backup policy
After a backup policy is deleted, the backup data that has already been generated by the backup policy is still available.
- Select the backup policy that you want to delete, and choose More > Delete in the Operation column. The Delete Backup Policy dialog box is displayed. See Figure 3.
- Confirm the deletion information and click OK.
