- Getting Started
- User Guide
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
API Description
VBS Backups
- Creating a VBS Backup
- Deleting a VBS Backup (Deprecated)
- Restoring a Disk Using a VBS Backup
- Creating a VBS Backup (Native OpenStack API) (Deprecated)
- Querying Summary Information About VBS Backups (Native OpenStack API) (Deprecated)
- Querying Details About VBS Backups (Native OpenStack API) (Deprecated)
- Querying Details About a VBS Backup (Native OpenStack API) (Deprecated)
- Querying the Job Status
- Deleting a VBS Backup (Native OpenStack API) (Deprecated)
- Restoring a Disk Using a VBS Backup (Native OpenStack API) (Deprecated)
- Sharing a Backup
- Canceling Sharing of a Backup
- Querying Backup Sharings
- Counting Backup Sharings
- Querying Details About a Backup Sharing
Backup Policies
- Creating a Backup Policy
- Querying Backup Policies
- Modifying a Backup Policy
- Deleting a Backup Policy
- Associating Resources with a Backup Policy
- Disassociating Resources from a Backup Policy
- Executing a Backup Policy At Once
- Enabling or Disabling a Backup Policy
- Querying Backup Jobs Triggered by a Backup Policy
- Adding a Tag to a Backup Policy
- Removing a Tag from a Backup Policy
- Querying All Backup Policy Tags
- Querying Tags of a Backup Policy
- Batch Updating or Removing Tags of a Backup Policy
- Querying Backup Policies by Tag
VBS Backups
- Appendix
- What Is Volume Backup Service?
- What Is a Backup Policy?
- What Are the Differences Between Backup and Disaster Recovery?
- How Do I Purchase and Renew VBS?
- What Are the Differences Between CSBS and VBS?
- Does VBS Support Simultaneous Backup of All EVS Disks on a Server?
- Do I Need to Stop the Server Before Backing Up EVS Disks on a Server Using VBS?
- How Long Does VBS Take to Back Up an EVS Disk?
- Does VBS Support Cross-Region Backup and Restoration?
- Do I Need to Stop the Server Before Restoring EVS Disk Data with a VBS Backup?
- What Is the Charging Mode of EVS Disks Created with a VBS Backup?
- Why Are CSBS Backups Displayed on the VBS Backup Page?
- Can a VBS Backup of a System Disk Be Used to Restore the System Disk of an ECS?
- Can I Use a VBS Backup to Restore an EVS Disk Whose Capacity Has Been Expanded?
- Is There a Quota Limit on the Number of Backups?
- What Can I Do In Case of Exceptions in VBS?
- Why Add Tags to a VBS Backup or Backup Policy?
- Does Backup Can Be Performed Several Times a Day?
- Can a Disk Only Be Associated With One Policy?
- What Are Full Backup and Incremental Backup?
- What Are the Differences Between Backups and Snapshots?
- Why Is the Remaining Space Not Changed After a Backup Is Deleted?
- Why Is the Disk Space Usage Displayed in the File System Different from the Backup Size?
- Why Does the Retention Rule Not Take Effect After Being Modified?
- How Do I Disable Automatic Backup?
- Videos
- Glossary
More Documents
User Guide (Paris)
- Getting Started
- Operation Guide
- Troubleshooting Cases
- Change History
API Reference (Paris)
- Before You Start
- API Overview
- Calling APIs
- Getting Started
API Description
VBS Backups
Backup Policies
VBS Backups
- Appendix
- Change History
User Guide (Paris)
Show all
Associating EVS Disks with a Backup Policy or Disassociating Them from a Backup Policy
After creating a backup policy, you can associate EVS disks to the backup policy. Later, the system will back up the EVS disks automatically according to the execution times specified in the backup policy. If an EVS disk no longer needs automatic backup, you can disassociate it from the backup policy.
- Click
. Under Storage, click Volume Backup Service.
- On the Volume Backup Service page, click Policies to go to the Policies tab page.
- Select an existing backup policy and click
. The list of associated EVS disks is displayed.
- Associating disks
- Click Associate. Alternatively, click Associate Disk in the Operation column.
The Associate Disk dialog box is displayed listing the EVS disks.
- Select the EVS disks that need to be associated with the backup policy (EVS disks in Expansion failed, Restoration failed, Rollback failed, Error, or Deletion failed state cannot be associated).
You can select EVS disks that have been associated with other backup policies. However, the system will disassociate them from the relevant backup policies and then associate them with the new backup policy.
- Optional: In the search box above the list, select a state and specify whether to search for an EVS disk by EVS disk name, EVS disk ID, or ECS ID and enter the corresponding value to search.
- Confirm the selected EVS disks to add them to the Selected Disks list on the right.
- Optional: In the search box above the Selected Disks list, specify whether to search for an EVS disk by its name or ID and enter the corresponding value to search. If the EVS disk is displayed, it has been selected.
- Confirm the settings and click OK to complete the association. See Figure 1.
If you select a large number (greater than 40) of EVS disks, the association operation may take a long time and a dialog box is displayed asking you whether to continue the association operation. Click OK to continue.
- Ensure that the backup policy is enabled. When the point in time specified by the backup policy arrives, select the backup policy. Then on the Backup Jobs panel, ensure that a backup job is generated.
- On the VBS backup list, locate the needed backup according to Name (the Backup Name specified in the backup job). When the Status is Available, the backup job of the associated EVS disks is complete.
- Disassociating EVS disks
- In the list of associated EVS disks, locate the EVS disk to be disassociated from the backup policy and click Disassociate in the Operation column.
The Disassociate Disk dialog box is displayed.
- Optional: In the list of associated EVS disks, select one or more EVS disks to be disassociated from the backup policy and click Disassociate above the list.
- Confirm the EVS disk information and click OK.
The Associated Disks panel does not display the EVS disks that are disassociated from this backup policy.
- Associating disks
