- Getting Started
- User Guide
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
API Description
VBS Backups
- Creating a VBS Backup
- Deleting a VBS Backup (Deprecated)
- Restoring a Disk Using a VBS Backup
- Creating a VBS Backup (Native OpenStack API) (Deprecated)
- Querying Summary Information About VBS Backups (Native OpenStack API) (Deprecated)
- Querying Details About VBS Backups (Native OpenStack API) (Deprecated)
- Querying Details About a VBS Backup (Native OpenStack API) (Deprecated)
- Querying the Job Status
- Deleting a VBS Backup (Native OpenStack API) (Deprecated)
- Restoring a Disk Using a VBS Backup (Native OpenStack API) (Deprecated)
- Sharing a Backup
- Canceling Sharing of a Backup
- Querying Backup Sharings
- Counting Backup Sharings
- Querying Details About a Backup Sharing
Backup Policies
- Creating a Backup Policy
- Querying Backup Policies
- Modifying a Backup Policy
- Deleting a Backup Policy
- Associating Resources with a Backup Policy
- Disassociating Resources from a Backup Policy
- Executing a Backup Policy At Once
- Enabling or Disabling a Backup Policy
- Querying Backup Jobs Triggered by a Backup Policy
- Adding a Tag to a Backup Policy
- Removing a Tag from a Backup Policy
- Querying All Backup Policy Tags
- Querying Tags of a Backup Policy
- Batch Updating or Removing Tags of a Backup Policy
- Querying Backup Policies by Tag
VBS Backups
- Appendix
- What Is Volume Backup Service?
- What Is a Backup Policy?
- What Are the Differences Between Backup and Disaster Recovery?
- How Do I Purchase and Renew VBS?
- What Are the Differences Between CSBS and VBS?
- Does VBS Support Simultaneous Backup of All EVS Disks on a Server?
- Do I Need to Stop the Server Before Backing Up EVS Disks on a Server Using VBS?
- How Long Does VBS Take to Back Up an EVS Disk?
- Does VBS Support Cross-Region Backup and Restoration?
- Do I Need to Stop the Server Before Restoring EVS Disk Data with a VBS Backup?
- What Is the Charging Mode of EVS Disks Created with a VBS Backup?
- Why Are CSBS Backups Displayed on the VBS Backup Page?
- Can a VBS Backup of a System Disk Be Used to Restore the System Disk of an ECS?
- Can I Use a VBS Backup to Restore an EVS Disk Whose Capacity Has Been Expanded?
- Is There a Quota Limit on the Number of Backups?
- What Can I Do In Case of Exceptions in VBS?
- Why Add Tags to a VBS Backup or Backup Policy?
- Does Backup Can Be Performed Several Times a Day?
- Can a Disk Only Be Associated With One Policy?
- What Are Full Backup and Incremental Backup?
- What Are the Differences Between Backups and Snapshots?
- Why Is the Remaining Space Not Changed After a Backup Is Deleted?
- Why Is the Disk Space Usage Displayed in the File System Different from the Backup Size?
- Why Does the Retention Rule Not Take Effect After Being Modified?
- How Do I Disable Automatic Backup?
- Videos
- Glossary
More Documents
User Guide (Paris)
- Getting Started
- Operation Guide
- Troubleshooting Cases
- Change History
API Reference (Paris)
- Before You Start
- API Overview
- Calling APIs
- Getting Started
API Description
VBS Backups
Backup Policies
VBS Backups
- Appendix
- Change History
User Guide (Paris)
Show all
Change History
Release Date |
Description |
2019-02-14 |
This issue is the fifth official release. Updated the following content: Added the "Quotas" section. |
2018-11-19 |
This issue is the fourth official release. Updated the following content: Split the document into several parts for release. |
2018-06-04 |
This issue is the third official release. Updated the following content:
2017-01-17 |
This issue is the second official release. Updated the following content:
2017-12-31 |
This issue is the first official release. |
