- Getting Started
- User Guide
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
API Description
VBS Backups
- Creating a VBS Backup
- Deleting a VBS Backup (Deprecated)
- Restoring a Disk Using a VBS Backup
- Creating a VBS Backup (Native OpenStack API) (Deprecated)
- Querying Summary Information About VBS Backups (Native OpenStack API) (Deprecated)
- Querying Details About VBS Backups (Native OpenStack API) (Deprecated)
- Querying Details About a VBS Backup (Native OpenStack API) (Deprecated)
- Querying the Job Status
- Deleting a VBS Backup (Native OpenStack API) (Deprecated)
- Restoring a Disk Using a VBS Backup (Native OpenStack API) (Deprecated)
- Sharing a Backup
- Canceling Sharing of a Backup
- Querying Backup Sharings
- Counting Backup Sharings
- Querying Details About a Backup Sharing
Backup Policies
- Creating a Backup Policy
- Querying Backup Policies
- Modifying a Backup Policy
- Deleting a Backup Policy
- Associating Resources with a Backup Policy
- Disassociating Resources from a Backup Policy
- Executing a Backup Policy At Once
- Enabling or Disabling a Backup Policy
- Querying Backup Jobs Triggered by a Backup Policy
- Adding a Tag to a Backup Policy
- Removing a Tag from a Backup Policy
- Querying All Backup Policy Tags
- Querying Tags of a Backup Policy
- Batch Updating or Removing Tags of a Backup Policy
- Querying Backup Policies by Tag
VBS Backups
- Appendix
- What Is Volume Backup Service?
- What Is a Backup Policy?
- What Are the Differences Between Backup and Disaster Recovery?
- How Do I Purchase and Renew VBS?
- What Are the Differences Between CSBS and VBS?
- Does VBS Support Simultaneous Backup of All EVS Disks on a Server?
- Do I Need to Stop the Server Before Backing Up EVS Disks on a Server Using VBS?
- How Long Does VBS Take to Back Up an EVS Disk?
- Does VBS Support Cross-Region Backup and Restoration?
- Do I Need to Stop the Server Before Restoring EVS Disk Data with a VBS Backup?
- What Is the Charging Mode of EVS Disks Created with a VBS Backup?
- Why Are CSBS Backups Displayed on the VBS Backup Page?
- Can a VBS Backup of a System Disk Be Used to Restore the System Disk of an ECS?
- Can I Use a VBS Backup to Restore an EVS Disk Whose Capacity Has Been Expanded?
- Is There a Quota Limit on the Number of Backups?
- What Can I Do In Case of Exceptions in VBS?
- Why Add Tags to a VBS Backup or Backup Policy?
- Does Backup Can Be Performed Several Times a Day?
- Can a Disk Only Be Associated With One Policy?
- What Are Full Backup and Incremental Backup?
- What Are the Differences Between Backups and Snapshots?
- Why Is the Remaining Space Not Changed After a Backup Is Deleted?
- Why Is the Disk Space Usage Displayed in the File System Different from the Backup Size?
- Why Does the Retention Rule Not Take Effect After Being Modified?
- How Do I Disable Automatic Backup?
- Videos
- Glossary
More Documents
User Guide (Paris)
- Getting Started
- Operation Guide
- Troubleshooting Cases
- Change History
API Reference (Paris)
- Before You Start
- API Overview
- Calling APIs
- Getting Started
API Description
VBS Backups
Backup Policies
VBS Backups
- Appendix
- Change History
User Guide (Paris)
Symptom
Failed to attach EVS disks despite following the procedure: Create EVS disks using the same VBS backup (XFS file system backup) and attach them to the same server (to which multiple EVS disks with XFS file system backup have been attached). Running the mount command to attach EVS disks fails.
Possible Causes
The superblock of an EVS disk (with XFS file systems) stores a universally unique identifier (UUID) about the file system. If a server has multiple disks (with XFS file systems), multiple UUIDs will exist on the server. Multiple disks may have the same UUID, which can cause the file system mounting to fail.
Fault Diagnosis
When attaching an EVS disk, use parameters without UUID control or reallocate a new UUID to ensure that each UUID is unique.
- Log in to the server to which EVS disks failed to be attached.
- Resolve the problem in either of the following ways:
- Use a parameter without UUID when attaching an EVS disk: Run mount -o nouuid /dev/Device name /Mount path, for example:
mount -o nouuid /dev/sda6 /mnt/aa
- Reallocate a new UUID: Run xfs_admin -U generate /dev/Device name.
Because setting a parameter without UUID requires you to execute the command every time, you are advised to reallocate a new UUID.
