- Getting Started
- User Guide
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
API Description
VBS Backups
- Creating a VBS Backup
- Deleting a VBS Backup (Deprecated)
- Restoring a Disk Using a VBS Backup
- Creating a VBS Backup (Native OpenStack API) (Deprecated)
- Querying Summary Information About VBS Backups (Native OpenStack API) (Deprecated)
- Querying Details About VBS Backups (Native OpenStack API) (Deprecated)
- Querying Details About a VBS Backup (Native OpenStack API) (Deprecated)
- Querying the Job Status
- Deleting a VBS Backup (Native OpenStack API) (Deprecated)
- Restoring a Disk Using a VBS Backup (Native OpenStack API) (Deprecated)
- Sharing a Backup
- Canceling Sharing of a Backup
- Querying Backup Sharings
- Counting Backup Sharings
- Querying Details About a Backup Sharing
Backup Policies
- Creating a Backup Policy
- Querying Backup Policies
- Modifying a Backup Policy
- Deleting a Backup Policy
- Associating Resources with a Backup Policy
- Disassociating Resources from a Backup Policy
- Executing a Backup Policy At Once
- Enabling or Disabling a Backup Policy
- Querying Backup Jobs Triggered by a Backup Policy
- Adding a Tag to a Backup Policy
- Removing a Tag from a Backup Policy
- Querying All Backup Policy Tags
- Querying Tags of a Backup Policy
- Batch Updating or Removing Tags of a Backup Policy
- Querying Backup Policies by Tag
VBS Backups
- Appendix
- What Is Volume Backup Service?
- What Is a Backup Policy?
- What Are the Differences Between Backup and Disaster Recovery?
- How Do I Purchase and Renew VBS?
- What Are the Differences Between CSBS and VBS?
- Does VBS Support Simultaneous Backup of All EVS Disks on a Server?
- Do I Need to Stop the Server Before Backing Up EVS Disks on a Server Using VBS?
- How Long Does VBS Take to Back Up an EVS Disk?
- Does VBS Support Cross-Region Backup and Restoration?
- Do I Need to Stop the Server Before Restoring EVS Disk Data with a VBS Backup?
- What Is the Charging Mode of EVS Disks Created with a VBS Backup?
- Why Are CSBS Backups Displayed on the VBS Backup Page?
- Can a VBS Backup of a System Disk Be Used to Restore the System Disk of an ECS?
- Can I Use a VBS Backup to Restore an EVS Disk Whose Capacity Has Been Expanded?
- Is There a Quota Limit on the Number of Backups?
- What Can I Do In Case of Exceptions in VBS?
- Why Add Tags to a VBS Backup or Backup Policy?
- Does Backup Can Be Performed Several Times a Day?
- Can a Disk Only Be Associated With One Policy?
- What Are Full Backup and Incremental Backup?
- What Are the Differences Between Backups and Snapshots?
- Why Is the Remaining Space Not Changed After a Backup Is Deleted?
- Why Is the Disk Space Usage Displayed in the File System Different from the Backup Size?
- Why Does the Retention Rule Not Take Effect After Being Modified?
- How Do I Disable Automatic Backup?
- Videos
- Glossary
More Documents
User Guide (Paris)
- Getting Started
- Operation Guide
- Troubleshooting Cases
- Change History
API Reference (Paris)
- Before You Start
- API Overview
- Calling APIs
- Getting Started
API Description
VBS Backups
Backup Policies
VBS Backups
- Appendix
- Change History
User Guide (Paris)
Data Restoration Using a VBS Backup
You can use VBS backups to restore EVS disks to a given point in time or create EVS disks. Data on the EVS disks is equivalent to the backup data.
Restore an EVS Disk Using a VBS Backup
You can use a VBS backup to restore an EVS disk to the time when the backup was created.
Before restoring the disk data, stop the server to which the EVS disk is attached and detach the EVS disk from the server. After the EVS disk data is restored, attach the EVS disk to the server and start the server.
- If a server disk has been backed up and the operating system was changed after the backup, the backup may not be able to restore the disk because of the disk ID change. In this case, you can use the backup to create a new disk and mount the new disk as a data disk to the server.
- Click
. Under Storage, click Volume Backup Service.
- On the Volume Backup Service page, if the Status of the VBS backup is Available, click Restore Disk in the Operation column.
- Click OK as prompted. See Figure 1. Then, check whether the data is restored successfully.
You can refresh the page after 10 seconds to view the data restoration status. When the Status of the backup changes back to Available, the restoration has been successfully completed.
Creating an EVS Disk Using a VBS Backup
You can use a VBS backup to create an EVS disk. After the EVS disk is created, the data on the new disk is the same as that in the VBS backup.
- Click
- In the My Backups or Backups shared with me list, confirm that the Status of the VBS backup is Available and click Create Disk in the Operation column.
- Set the disk parameters.
For details about these parameters, see the parameter description table in section Purchasing an EVS Disk in the Elastic Volume Service User Guide.
Note the following items when setting disk parameters:
- You can choose the same AZ to which the owning EVS disk of the backup data belongs, or you can choose a different AZ.
- The capacity of the newly created EVS disk cannot be smaller than that of the source EVS disk of the backup data.
If it is larger than the backup capacity, initialize the incremental disk space. For details, see section Initializing an EVS Disk (Linux) in the Elastic Volume Service User Guide.
- You can create a disk of any type regardless of the backup's disk type.
- Batch creation is not supported when using backup data to create EVS disks. You can create only one EVS disk at a time.
- Click Buy Now.
You can choose Pay-per-use or Yearly/Monthly as your Billing Mode. Fees you should pay vary depending on the billing mode you choose. The following steps use billing mode Yearly/Monthly as an example.
- Confirm the VBS backup information and click Submit.
- Pay the fees as prompted and click OK.
- Switch back to the Elastic Volume Service page. Check whether the EVS disk is successfully created.
It takes more than 10 minutes to create an EVS disk using a VBS backup.
During EVS disk creation, the four intermediate states Creating, Available, Restoring, and Available will be displayed in sequence. If the state changes from Creating to Available, the EVS disk is successfully created. If the state changes from Restoring to Available, backup data is successfully restored to the created EVS disk.
