Help Center/
      Database and Application Migration UGO/
        User Guide/
        Error Codes/
        Authentication Errors/
      UGO.10080006 Access keys exceed the quota
        Updated on 2025-06-07 GMT+08:00
The number of access keys created by a user exceeds the quota.
Possible Causes
By default, each user can create a maximum of 100 access keys. The number of access keys has exceeded the limit.
Handling Suggestion
- Delete unnecessary access keys.
 - Log in to a UGO server and change the value of user.create.access.key.number in the <common.install.path>/services/UGO_IAMService/config/application.properties configuration file.
   Parent topic: Authentication Errors
