Help Center/
Database and Application Migration UGO/
User Guide/
Syntax Conversion/
Risky Custom Functions/
Replacing Custom MySQL Functions with GaussDB Functions/
asin
Updated on 2025-06-07 GMT+08:00
asin
Database Type and Version
- Source database type and version: all MySQL versions
- Target database type and version: all GaussDB versions
Function replacement syntax:
CREATE OR REPLACE FUNCTION dsc_mys_ext.dsc_fn_asin /* This function is used to support MYSQL ASIN */ ( i_str IN TEXT ) RETURN NUMBER IMMUTABLE AS v_asin NUMBER; BEGIN IF i_str < -1.00 or i_str > 1.00 THEN RETURN NULL; ELSE SELECT ASIN(i_str) into v_asin from sys_dummy; RETURN v_asin; END IF; EXCEPTION WHEN OTHERS THEN v_asin := 0; RETURN v_asin; END;
Parent topic: Replacing Custom MySQL Functions with GaussDB Functions
