Help Center/
Database and Application Migration UGO/
User Guide/
SQL Audit/
Rules/
Copying a Rule Template
Updated on 2025-10-22 GMT+08:00
You can copy an existing template to create a custom template.
There is a rule template.
- Log in to the UGO console.
- In the navigation pane on the left, choose SQL Audit > Rules. The Templates page is displayed by default.
- Select the template to be copied and click Copy in the Operation column.
The template name must be unique and cannot be empty. The baseline template is the template to be copied.Figure 1 Copying a template
- Click OK. The copied template is displayed in the template list.
Parent topic: Rules
