On this page
Show all
Checking GUC Parameters
Updated on 2025-02-24 GMT+08:00
GaussDB provides many GUC parameters to manage behaviors of the database system. UGO converts SQL syntax based on a group of GUC parameters that are compatible with the source database. Set GUC parameters as prompted during the object migration pre-check. Otherwise, the success rate and availability of the final object migration may be affected.
This check item is displayed when the target database type is GaussDB V2.0-3.1 or later and the source database type is Oracle, Microsoft SQL Server, or MySQL. Check whether GUC parameters are configured. For details, see Table 1.
  • The GUC parameter check is performed based on the target database version you selected during evaluation project creation, instead of the target database version that is actually connected.
  • If the target database type is GaussDB Centralized (M-compatible mode), GUC parameters cannot be checked.
  • For details about how to set the GaussDB GUC parameters, see the check item prompt on the pre-check page or see How Do I Set GaussDB GUC Parameters?
Table 1 GUC parameter check items
Source DB Type
Target DB Version
Check Item
MySQL
GaussDB Centralized V2.0-3.1 Enterprise Edition
GaussDB Centralized V2.0-3.2 Enterprise Edition
b_format_behavior_compat_options
GaussDB Distributed V2.0-3.2 Enterprise Edition
GaussDB Centralized V2.0-8.0 Enterprise Edition
b_format_version, b_format_dev_version
GaussDB Distributed V2.0-8.0 Enterprise Edition
GaussDB Centralized V2.0-8.100 Enterprise Edition
GaussDB Distributed V2.0-8.100 Enterprise Edition
GaussDB Centralized (M-compatible mode) V2.0-8.100 Enterprise Edition
m_format_behavior_compat_options, m_format_dev_version
GaussDB Centralized (M-compatible mode) V2.0-8.200 Enterprise Edition
GaussDB Centralized (M-compatible mode) V2.0-9.0 Enterprise Edition
Oracle
behavior_compat_options, sql_beta_feature, a_format_version, a_format_dev_version
behavior_compat_options, plsql_compile_check_options, sql_beta_feature, a_format_version, a_format_dev_version
GaussDB Centralized V2.0-3.3 Enterprise Edition
behavior_compat_options, plsql_compile_check_options, sql_beta_feature, IntervalStyle, a_format_version, a_format_dev_version
GaussDB Distributed V2.0-3.3 Enterprise Edition
behavior_compat_options, sql_beta_feature, IntervalStyle, a_format_version, a_format_dev_version
GaussDB Centralized V2.0-8.200 Enterprise Edition
behavior_compat_options, plsql_compile_check_options, sql_beta_feature, IntervalStyle, a_format_version, a_format_dev_version, a_format_date_timestamp
GaussDB Distributed V2.0-8.200 Enterprise Edition
behavior_compat_options, sql_beta_feature, IntervalStyle, a_format_version, a_format_dev_version, a_format_date_timestamp
GaussDB Centralized V2.0-9.0 Enterprise Edition
behavior_compat_options, plsql_compile_check_options, sql_beta_feature, IntervalStyle, mapping_date_to_datea, a_format_version, a_format_dev_version, a_format_date_timestamp
GaussDB Distributed V2.0-9.0 Enterprise Edition
behavior_compat_options, sql_beta_feature, IntervalStyle, mapping_date_to_datea, a_format_version, a_format_dev_version, a_format_date_timestamp
CAUTION:
The plsql_compile_check_options parameter of GaussDB Centralized is used to verify all statements in functions, procedures, and packages. If there are undefined objects in the statements, an alarm is reported. To avoid false alarms in the production environment, this parameter is recommended only in the test environment.
