Help Center/
Database and Application Migration UGO/
User Guide/
Conversion Configuration/
Deleting a Conversion Configuration Template
Updated on 2025-10-22 GMT+08:00
You can delete conversion configuration templates. Deleted templates cannot be restored. Exercise caution when performing this operation.
You have created a template.
Templates frozen for security reasons cannot be deleted.
- Log in to the UGO console.
- In the navigation pane, choose Conversion Configuration.
- Locate a template that you want to delete and click Delete in the Operation column. You can also select multiple templates and click Delete above the list.
- Click OK.
Parent topic: Conversion Configuration
