Help Center/ Database and Application Migration UGO/ User Guide/ Syntax Conversion/ Conversion Error Codes/ Error Codes Generated During Conversion from MariaDB to GaussDB/ U1100004: GaussDB (A-compatible mode) does not support FLOAT(p,s)
Updated on 2026-10-27 GMT+08:00
Database Type and Version
- Source database type and version: all MariaDB versions
- Target database type and version: all versions of GaussDB (Oracle-compatible mode)
Syntax Example
GaussDB (A-compatible mode) does not support FLOAT(p,s) where both precision and scale are specified.
MariaDB syntax:
CREATE TABLE test_float(
C1 FLOAT(2,1)
); Suggestion
Modify Support for FLOAT.
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
