Help Center/
Database and Application Migration UGO/
User Guide/
Syntax Conversion/
Conversion Error Codes/
Error Codes Generated During Conversion from SQL Server to TaurusDB for PostgreSQL
Updated on 2025-06-07 GMT+08:00
- U0530001: The target database does not support the feature represented by the keyword
- U0530002: TaurusDB for PostgreSQL does not support variables in UPDATE
- U0530003: TaurusDB for PostgreSQL does not support method names in UPDATE
- U0530004: TOP does not work in INSERT...EXEC for TaurusDB for PostgreSQL
- U0530005: TaurusDB for PostgreSQL does not support temporary stored procedures
Parent topic: Conversion Error Codes
