Viewing the Test Quality Dashboard
CodeArts TestPlan provides dashboards with more than 10 quality metrics, such as the requirement coverage rate, requirement pass rate, case execution rate, and legacy DI, for evaluation of functions, performance, and reliability. You can clearly learn about the progress and risks of the overall test plan through the dashboard.
Project-Level Dashboard
The project dashboard displays statistics on the test case library and test plan. The items include the requirement coverage rate, number of bugs, test case pass rate, test case completion rate, and details of associated bugs.
Quality Report of the Test Case Library
Log in to the CodeArts homepage and search for and access the target project. In the navigation pane, choose Testing > Quality Report. The quality report page is displayed by default.
Report Item | Description |
Requirement Coverage | Percentage of tested requirements in the selected sprint and module. This reflects function test coverage. To view the requirements associated with the current test plan, click the Requirement Test tab.
NOTE: In Scrum projects, only statistics on the Feature and Story requirements are collected by default. To collect statistics on the Epic requirements, select epic. |
Bug | Collects statistics on the number of unresolved defects and the total number of defects in the selected sprint and module. The statistics are grouped by defect severity. NOTE: The number of unresolved bugs includes the following:
Case Pass Rate | Pass rate of test cases in the selected sprint and module. The test case pass rate and bugs reflect the overall product quality. The statistics are grouped based on the execution result. The test cases that are not executed are included in the Not executed group. Case pass rate =Number of successful test cases/Total number of test cases |
Manual Test | Collects statistics on the requirement coverage rate, total number of defects, case pass rate, and case completion rate associated with manual test cases in the selected sprint and module. |
Auto API Test | Collects statistics on the requirement coverage rate, total number of defects, case pass rate, and case completion rate associated with automated API test cases in the selected sprint and module. |
Defects | List of bugs associated with test cases in the selected sprint and module. Click |
Test Cases | List of test cases in the selected sprint and module. Click |
Quality Report of a Test Plan
On the Quality Report page, click the Test case Library drop-down list in the upper left corner and select a test plan. The quality report page of the selected test plan is displayed.
The quality report of a test plan is not filtered by sprint or module. In addition, it shows the test case completion rate and the risk description of the test plan. Other report items are the same as those of the quality report of the test case library.
Case Completion Rate | Number of completed test cases in the selected plan. This reflects the test progress. The statistics are grouped by case status. Completion rate =Number of completed cases/Total number of cases |
Risk | Risk of the test plan. You can evaluate the risk level of the test plan and add risk description. |
Manual Test | Requirement coverage rate, total number of bugs, pass rate, and completion rate of manual test cases. |
Auto API Test | Requirement coverage rate, total number of bugs, pass rate, and completion rate of automated API test cases. |
Personal Dashboard
- Personal case completion rate, case pass rate, submitted bug status, submitted bug severity, bug statistics based on the test case library and test plan in the project
- Personal test plans, test tasks, and submitted bugs based on the test case library and test plan in the project
Custom Test Reports
Create a custom test report in either of the following ways:
- On the homepage
- Log in to the CodeArts homepage. On the top navigation bar, choose Services > TestPlan. The homepage is displayed.
- Click Create Report in the upper right corner, or click Add Report in the lower left corner.
- On the displayed Select Report Type page, select the type of the report to be created.
- On the quality report page
- Log in to the CodeArts homepage, search for your target project, and click the project name to access the project.
- In the navigation pane, choose Testing > Quality Report.
- Select the test case library or a test plan, click Add Report in the lower left corner of the page, and select the type of the report to be created.
