Generating a Random Decimal in a Specified Range
Function Name
$randomDecimal(double A, double B, int C)
Function Description
Generates a random decimal with C decimal places within the range between parameter A and parameter B. CodeArts TestPlan can generate random decimals with up to 9 decimal places, within the range of [–9999999999.999999999, +9999999999.999999999].
Parameters A and B support the following types:
- Decimals or integers
 - Environment parameters
 - Local parameters
 - Other built-in functions
Parameter C supports the following types:
- Positive integers
 - Local parameters
If C is 0, the function generates a random integer.
Application Scenarios
The function for generating random decimals within a specified range can be used in the following scenarios for API automation:
- Request URL
 - Request header
 - Request body
 - Checkpoint property
 - if condition
 - for loop interrupt condition
Example
- Request URL
As shown in the following figure, the value of test in the request URL is the function for generating random decimals within a specified range. Parameter A in the function is 1, parameter B is 100, and parameter C is 2.
 - Request header
As shown in the following figure, the value of number in the request header is the function for generating random decimals within a specified range. Parameter A in the function is 1, parameter B is 100, and parameter C is 2.
 - Request body
As shown in the following figure, the request body uses the function for generating random decimals within a specified range. Parameter A in the function is the binary addition operation $add(1,1). Parameter B is the binary multiplication operation $multiply(10,10).
Parameter C is 2.
As shown in the following figure, the target value of the checkpoint property result is the function for generating random decimals within a specified range. Parameter A in the function is 1, parameter B is the local parameter test, and parameter C is 2. For details about how to set local parameters, see Local Parameters.
 - if condition
As shown in the following figure, the target value of the if condition is the function for generating random decimals within a specified range. Parameter A in the function is 1, parameter B is the environment variable status, and parameter C is 2. For details about how to set environment parameters, see Setting Environment Parameters of an API Script.
As shown in the following figure, the target value of the for loop interrupt condition is the function for generating random decimals within a specified range. Parameter A in the function is 1, parameter B is 100, and parameter C is 2.
