Updated on 2026-08-11 GMT+08:00
Setting WeCom Subscriptions
When any of the following events occurs, CodeArts TestPlan sends a message through HTTP to the WeCom group that has subscribed to the event.
TestPlan
Table 1 Event types
Category
Event Type
Test case
Assign Case Handler
Update Case
Execute Manual Test Case
API Test Case Execution Completed
Delete Case
Test suite
Create Test Suite
Update Test Suite
Delete Test Suite
Test Suite Execution Completed
Test report
Create Report
Update Report
Delete Report
Branch plan
Create Plan
Change Plan
Edit Risk Info (on the test quality dashboard)
Delete Plan
Delete Branch
Send Quality Report upon Test Plan Completion
Directory
Delete Directory
Comment notification
Comment Notification (comment changes in manual test cases)
You have created a CodeArts project, and your role in the project is Project Administrator or Project Manager.
  1. Go to the CodeArts homepage.
  2. Click the target project name to go to the project.
  3. In the navigation pane, choose Settings > General > Notifications.
  4. Click the WeCom tab.
  5. Configure the required parameters and click OK.
    Table 2 Setting WeCom Subscriptions
    URL
    The webhook URL of your WeCom group robot. It must start with http:// or https://. The URL cannot exceed 256 characters.
    For details about how to obtain the webhook URL of your WeCom group robot, see section "How to set group robot" in the WeCom Help Center. (The section name is subject to updates of the WeCom Help Center.)
    Event Type
    Event type that can trigger a WeCom notification. For details about the supported event types, see Scenarios.
    Content
    Content of the WeCom notification. For details about the configurable content, see Scenarios.
    This parameter is optional. Configure it as needed.
    @user_id
    WeCom user IDs of the members you want to mention. Separate the IDs with semicolons (;). The total length of all IDs cannot exceed 1,000 characters. Digits, letters, semicolons (;), periods (.), hyphens (-), underscores (_), and at signs (@) are supported.
    The updated configuration is displayed.
