KafkaProducer
Introduction to KafkaProducer
This system keyword can be used to test Kafka producers.
        Parameter  |
        Mandatory  |
        Type  |
        Default Value  |
        Description  |
        Broker  |
        Yes  |
        String  |
        127.0.0.1:9093  |
        IP address of a Kafka instance  |
        Topic  |
        Yes  |
        String  |
        Topic of a Kafka message  |
        Message  |
        Yes  |
        String  |
        Body of each Kafka message  |
        SASL Username  |
        No  |
        String  |
        Kafka SASL username  |
        SASL Password  |
        No  |
        String  |
        Kafka SASL password  |
        Truststore  |
        No  |
        File  |
        Kafka client certificate  |
        Truststore Password  |
        No  |
        String  |
        Password of the Kafka client certificate  |
Kafka Authentication Description
- Authentication mode: If you configure SASL Username, SASL Password, Truststore, and Truststore Password in the KafkaProducer keyword, and the Kafka uses the SASL_SSL authentication protocol for encrypted data transmission, then client authentication is required.
 - No authentication mode: If you do not configure SASL Username, SASL Password, Truststore, and Truststore Password in the KafkaProducer keyword, and the Kafka uses the default SASL_PLAINTEXT protocol, then no encryption or authentication mechanism will be used. In this mode, the communication between the client and server is in plaintext, and security cannot be guaranteed.
KafkaProducer Response
Status: success
        Parameter  |
        Type  |
        Description  |
        Body  |
        String  |
        Value returned by the KafkaProducer API  |
KafkaProducer Response Example
  "result" : "send message to kafka success.",
  "status" : "ok"
 Default Checkpoint
        Name  |
        Expected Value  |
        Result  |
        Success  |
KafkaProducer Usage Example
Configure parameters to send a Kafka message.
