WSReadOnly
This system keyword is used to access a WebSocket server for read-only operations.
| Parameter | Mandatory | Type | Description |
| Request Uri | Yes | String | WebSocket service address |
| Response Timeout | Yes | Long | Response timeout period |
| Header | Yes | String | Request header |
| Response Type | Yes | String | Response data type |
WSReadOnly Response
Status: success
| Parameter | Type | Description |
| Body | String | Value returned by the WSReadOnly API |
WSReadOnly Response Example
"Read data from*** at port *** successfully. response: this is a response message."
} Default Checkpoint
| Name | Expected Value |
| Result | Success |
WSReadOnly Usage Example
Configure parameters to access the WebSocker service.
