WSConnect
This system keyword is used for connecting a WebSocket client to a server.
       Parameter  |
       Mandatory  |
       Type  |
       Description  |
       Request Uri  |
       Yes  |
       String  |
       WebSocket service address  |
       Response Timeout  |
       Yes  |
       Long  |
       Response timeout period  |
       Header  |
       Yes  |
       String  |
       Request header  |
       Connect Timeout  |
       Yes  |
       Integer  |
       Connection timeout period  |
WSConnect Response
Status: success
        Parameter  |
        Type  |
        Description  |
        Body  |
        String  |
        Value returned by the WSConnect API  |
WSConnect Response Example
    "Connect to *** at port *** in time 5000 successfully."
 Default Checkpoint
        Name  |
        Expected Value  |
        Result  |
        Success  |
WSConnect Usage Example
Configure parameters to access the WebSocker service.
