Updated on 2025-08-19 GMT+08:00
Test Case Fields
If the preset test case fields do not meet your actual requirements, you can add custom fields.
- Log in to the CodeArts homepage, search for your target project, and click the project name to access the project.
- In the navigation pane, choose Settings > Testing.
- Click the Test Case Settings tab. Test case fields are displayed on the tab page.
- Configure the fields:
- Click
in the Operation column to modify the names of some fields, add or delete options, and enable or disable Show or Required. - Enable or disable Display or Required on the setting page.
- Click the drop-down list box of the default value of a field and select a value as the default value of the field after a test case is created.
- Click
in the Operation column to delete a field.
- Click
Adding a Custom Field
You can set custom fields. Custom fields are displayed in the details of test cases.
- In the Test Case Settings tab page, click Add Field. Max. 25 custom fields can be added.
- Set Field Name, Description, and Field Type, enable or disable Show and Required, and click OK.
- Single-line text: Only one line can be entered in this field. The maximum length is 100 characters.
- Multi-line text: Multiple lines of fields can be entered in this field. The maximum length is 2,000 characters.
- Single-choice list: Only one option can be selected in this field. Click Add Option and set the required options for the field. Up to 300 options can be added.
- Multi-choice list: Multiple options can be selected in this field. Click Add Options and set the required options for the field. A maximum of 20 options can be added.
- Date Time: Field for setting date and time.
- Date: Field for setting date.
- Number: Field for entering an integer ranging from –9999999999 to 9999999999.
- Decimal: Field for entering a decimal up to two decimal places.
- Single-choice user: Field for selecting a user from the drop-down list box.
- Multi-choice user: Field for selecting multiple users from the drop-down list box.
- The created field is displayed in the list. To edit the field, click
. To delete the field, click
Parent topic: Settings
