RedisGet
This system keyword is used for Redis character string operations to obtain the value of a specified key.
| Parameter | Mandatory | Type | Description |
| Ip | Yes | String | IP address of the Redis database |
| Port | Yes | Integer | Redis database port |
| Password | Yes | String | Password (The login password is personal information and must be defined as sensitive in the environment parameters.) |
| Key | Yes | String | Specified key name |
RedisGet Response
Status: success
| Parameter | Type | Description |
| key | String | Value of the specified key |
RedisGet Response Example
"test" : "Redis"
} What is your overall rating for this page?
