MySQLInsert
This system keyword is used for data insertion on MySQL database.
       Parameter  |
       Mandatory  |
       Type  |
       Description  |
       Ip  |
       Yes  |
       String  |
       Database IP address. For a Huawei Cloud RDS instance, bind an EIP to the instance and ensure that the security group policy of the instance port is enabled to allow access. For details, see Using MySQL CLI to Connect to an Instance Through a Public Network.  |
       Port  |
       Yes  |
       Integer  |
       Database port  |
       DB Name  |
       Yes  |
       String  |
       Database instance name  |
       User Name  |
       Yes  |
       String  |
       Username  |
       Password  |
       Yes  |
       String  |
       Password (The login password is personal information and must be defined as sensitive in the environment parameters.)  |
       Sql  |
       Yes  |
       String  |
       SQL statement, such as INSERT, which has no returns  |
MySQLInsert Response
Status: success
        Parameter  |
        Type  |
        Description  |
        affected_row_count  |
        Integer  |
        Number of rows affected by the SQL statement  |
MySQLInsert Response Example
 "affected_row_count": 1
 MySQLInsert Usage Example
Determine the number of affected rows.
