MongoDBInsert
This system keyword is used to insert documents into collections in the MongoDB database.
| Parameter | Mandatory | Type | Description |
| Ip | Yes | String | Database IP address |
| Port | Yes | Integer | Database port |
| User Name | Yes | String | Username |
| Password | Yes | String | Password (The login password is personal information and must be defined as sensitive in the environment parameters.) |
| DB Name | Yes | String | Database instance name |
| Collection | Yes | String | Collection name |
| Bson | Yes | String | Inserted data (in BSON format) |
MongoDBInsert Response
| Parameter | Type | Description |
| affected_row_count | Integer | Number of rows affected by document insertion |
MongoDBInsert Response Example
"affected_row_count" : 1
} MongoDBInsert Usage Example
Insert data into a collection based on the input test parameter. The system keyword returns the number of inserted records.
Check whether the result is successful through the test checkpoint.
