MongoDBQuery
Updated on 2024-10-11 GMT+08:00
This system keyword is used for query operations on the MongoDB database. A maximum of 100 records can be queried in the system.
Mandatory
Type
Ip
Yes
String
Database IP address
Port
Yes
Integer
Database port
User Name
Yes
String
Username
Password
Yes
String
Password (The login password is personal information and must be defined as sensitive in the environment parameters.)
DB Name
Yes
String
Database instance name
Collection
Yes
String
Collection name
Query
No
String
Query conditions (data in BSON format). By default, this parameter is left blank to query all data in the collection. A maximum of 100 records can be queried in the system.
Limit
No
Integer
  • Maximum number of records in the query result. By default, this parameter is left blank to query all data in the collection. A maximum of 100 records can be queried in the system.
  • If the value is a number out the range of 0 to 100, a maximum of 100 records can be queried in the system.
MongoDBQuery Response
Status: success
Type
[Array elements]
Array of row objects
Structure returned by the query result list
Parameter Description
Type
field1
String
Database field 1
field2
Integer
Database field 2
String
Database field n
MongoDBQuery Response Example
  "_id" : {
    "$oid" : "62465c42907c00003d0076fe"
  "title" : "MongoDB Tutorial",
  "description" : "MongoDB is a NoSQL database.",
  "by" : "test",
  "url" : "",
  "tags" : [ "mongodb", "database", "NoSQL" ],
  "likes" : 100.0
  "_id" : {
    "$oid" : "62465ce4907c00003d0076ff"
  "title" : "PHP Tutorial",
  "description" : "PHP is a powerful server-side scripting language for creating dynamic interactive sites.",
  "by" : "test",
  "url" : "",
  "tags" : [ "php" ],
  "likes" : 200.0
  "_id" : {
    "$oid" : "62465ce8907c00003d007700"
  "title" : "Java Tutorial",
  "description" : "Java is a high-level programming language launched by Sun Microsystems in May 1995.",
  "by" : "test",
  "url" : "",
  "tags" : [ "java" ],
  "likes" : 150.0
MongoDBQuery Usage Example
  • Query the number of documents in the database collection. The system returns the document data list based on the system keyword. You can determine the returned result based on the service.
    You can determine the result based on the returned list. For example, the number of documents in the collection is 10.
  • Query user data and extract data. The queried data list is returned.
    Extract or determine the result from response information.
