UDP
UDP
This system keyword is used to test the UDP basic protocol. Ensure that the user IP address is accessible from the public network and the security group policy of the corresponding port is enabled to permit access.
        Parameter  |
        Mandatory  |
        Type  |
        Default Value  |
        Description  |
        Host  |
        Yes  |
        String  |
        UDP service address  |
        Port  |
        Yes  |
        Integer  |
        UDP service port  |
        Check End Type  |
        Yes  |
        Enum  |
        CheckEndStr  |
        Message end flag: CheckEndLength CheckEndStr  |
        Body Type  |
        Yes  |
        Enum  |
        CharSequence  |
        Message body type: CharSequence HexadecimalCodeStream  |
UDP Response
         Parameter  |
         Type  |
         Description  |
         Body  |
         String  |
         UDP API return  |
UDP Response Example
    "This is a test Message."
 Default Checkpoint
        Name  |
        Expected Value  |
        Result  |
        Success  |
