Updated on 2025-08-19 GMT+08:00
TCP
TCP
This system keyword is used to test the TCP basic protocol. Ensure that the user IP address is accessible from the public network and the security group policy of the corresponding port is enabled to permit access.
Mandatory
Type
Default Value
Host
Yes
String
TCP service address
Port
Yes
Integer
TCP service port
Connect Timeout
Yes
Integer
TCP service connection timeout
Unit: millisecond
Read Timeout
Yes
Long
Message reading timeout
Unit: millisecond
Check End Type
Yes
Enum
CheckEndStr
Message end flag:
CheckEndLength
CheckEndStr
Body Type
Yes
Enum
CharSequence
Message body type:
CharSequence
HexadecimalCodeStream
TCP Response
Status: success
Type
Body
String
TCP API return
TCP Response Example
    "This is a test Message."
Default Checkpoint
Name
Expected Value
Result
Success
TCP Usage Example
Configure parameters to access the TCP service.
