Obtaining a Specified Timestamp
Function Name
$getTimeBeforeHour(doubleA)
Function Description
Obtains the timestamp of the time that is A hours ago. The timestamp is the total number of milliseconds from 1970-01-01 00:00:00 to the specified time.
Parameter A in the function supports the following types:
- Numbers
- Local parameters
- Other built-in functions
Application Scenarios
The function for obtaining the specified timestamp can be used in the following scenarios for API automation:
- Request URL
- Request header
- Request body
- Checkpoint property
- if condition
- for loop interrupt condition
Example
- Request URL
As shown in the following figure, the value of test in the request URL is the function for obtaining the specified timestamp. Parameter A in the function is 3.
- Request header
As shown in the following figure, the value of time in the request header is the function for obtaining the specified timestamp. Parameter A in the function is 3.
- Request body
As shown in the following figure, the request body uses the function for obtaining the specified timestamp. Parameter A in the function is the binary addition operation $add(2,2).
As shown in the following figure, the target value of the checkpoint property result is the function for obtaining the specified timestamp. Parameter A in the function is the local parameter test. For details about how to set local parameters, see Local Parameters.
- if condition
As shown in the following figure, the target value of the if condition is the function for obtaining the specified timestamp. Parameter A in the function is the environment variable time. For details about how to set environment parameters, see Setting Environment Parameters of an API Script.
As shown in the following figure, the target value of the for loop interrupt condition is the function for obtaining the specified timestamp. Parameter A in the function is 3.
