- Getting Started
- Terraform Basics
- User Guide
- FAQs
- Reference
On this page
Binding an EIP
Application Scenario
Purchase an EIP and bind it to the ECS.
Related Resources
- Add the following information to the main.tf file:
resource "huaweicloud_vpc_eip" "myeip" { publicip { type = "5_bgp" } bandwidth { name = "mybandwidth" size = 8 share_type = "PER" charge_mode = "traffic" } } resource "huaweicloud_compute_eip_associate" "associated" { public_ip = huaweicloud_vpc_eip.myeip.address instance_id = huaweicloud_compute_instance.myinstance.id }
- Run terraform plan to view resources.
- After you confirm that the resource information is correct, run terraform apply to purchase the EIP and bind the EIP to the ECS.
Parent topic: Elastic Cloud Server (ECS)
