Help Center/ TaurusDB_TaurusDB for PostgreSQL/ User Guide/ Database Proxy (Read/Write Splitting)/ Changing Configurations of a Proxy Instance/ Changing the Specifications of a Proxy Instance
Updated on 2026-02-06 GMT+08:00
If the proxy instance specifications cannot meet your workload requirements, you can manually upgrade them.
- The proxy instance specifications can be changed only when your TaurusDB for PostgreSQL instance, primary node, and read replicas are all normal.
- A proxy instance cannot be deleted when its CPU and memory specifications are being changed.
- Log in to the TaurusDB console.
- On the Instances page, click the instance name.
- In the navigation pane, choose Database Proxy.
- On the Database Proxy page, locate the desired proxy instance and click Change Specifications in the Operation column. Figure 1 Changing proxy instance specifications
Alternatively, click the proxy instance name. In the Proxy Instance Information area, click Change under Specifications.
Figure 2 Changing proxy instance specifications
- In the displayed dialog box, select new specifications and click OK. You can reduce or expand the specifications as required.
- View the new specifications on the Database Proxy page.
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
