Help Center/ TaurusDB_TaurusDB for PostgreSQL/ User Guide/ Database Proxy (Read/Write Splitting)/ Proxy Instance Lifecycle/ Deleting a Proxy Instance
Updated on 2026-02-06 GMT+08:00
You can delete a proxy instance as required.
If a proxy instance is deleted, read/write splitting is disabled and workloads using the proxy address are interrupted. You need to connect your applications to the TaurusDB instance address.
- Log in to the TaurusDB console.
- On the Instances page, click the instance name.
- In the navigation pane, choose Database Proxy.
- Locate a proxy instance and choose More > Delete in the Operation column.
- In the displayed dialog box, enter DELETE and click OK. Figure 1 Deleting a proxy instance
- Check the task progress on the Task Center page and refresh the Basic Information page of the proxy instance later. If the TaurusDB for PostgreSQL instance status becomes Available, the proxy instance is deleted successfully.
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
