Updated on 2025-11-14 GMT+08:00
Deleting a Task Record
You can delete task records so that they are no longer displayed in the task list. This operation only deletes the task records. It does not delete the DB instances or terminate the tasks that are being executed.
Deleted task records cannot be recovered. Exercise caution when performing this operation.
Deleting an Instant Task Record
  2. Click in the upper left corner and select a region.
  3. Click in the upper left corner of the page and choose Databases > TaurusDB.
  4. Choose Task Center in the navigation pane. On the displayed Instant Tasks page, locate the task record to be deleted and click Delete in the Operation column. In the displayed dialog box, click OK.
    You can delete the records of instant tasks in the following statuses:
    • Completed
    • Failed
Deleting a Scheduled Task Record
  4. Choose Task Center in the navigation pane. On the Scheduled Tasks page, locate the task record to be deleted and check whether the task status is To be executed or To be authorized.
    • If yes, go to 5.
    • If no, go to 6.
  5. Click Cancel in the Operation column. In the displayed dialog box, click Yes to cancel the task. Click Delete in the Operation column. In the displayed dialog box, click OK to delete the task record.
  6. Click Delete in the Operation column. In the displayed dialog box, click OK to delete the task record.
    You can delete the records of scheduled tasks in the following statuses:
    • Completed
    • Failed
    • Canceled
    • To be executed
    • To be authorized
