Viewing a Task
You can view the progress and results of scheduled tasks on the Task Center page.
Supported Tasks
| Task Type | Category | Task Name |
| Instant tasks | Instance creation | Creating a TaurusDB for PostgreSQL instance |
| Instance lifecycle | Rebooting a TaurusDB for PostgreSQL instance | |
| Stopping a TaurusDB for PostgreSQL instance | ||
| Instance modifications | Scaling a TaurusDB for PostgreSQL instance | |
| Backup and restoration | Restoring to a new TaurusDB for PostgreSQL instance, restoring to an existing TaurusDB for PostgreSQL instance, restoring TaurusDB for PostgreSQL databases, and restoring TaurusDB for PostgreSQL tables | |
| Parameter configuration | Modifying a TaurusDB for PostgreSQL parameter template | |
| Scheduled tasks | Instance lifecycle | Starting a TaurusDB for PostgreSQL instance |
Viewing an Instant Task
- Click
in the upper left corner and select a region. - Click
in the upper left corner of the page and choose Databases > TaurusDB. - On the Task Center page, locate the target task and view its details.
Viewing a Scheduled Task
- Click
in the upper left corner of the page and choose Databases > TaurusDB. - Choose Task Center in the navigation pane. On the Scheduled Tasks page, view the task progress and results.
- To identify the target task, you can use the DB instance name/ID or enter the target DB instance ID in the search box in the upper right corner.
- You can view the scheduled tasks in the following statuses:
- Running
- Completed
- Failed
- Canceled
- To be executed
- To be authorized
