Downloading SQL Audit Logs
If you enable SQL audit, all SQL operations will be logged, and you can download audit logs to view details. The minimum time unit of audit logs is second.
- Click
in the upper left corner and select a region. - Click
in the upper left corner of the page and choose Databases > TaurusDB. - On the Instances page, click the instance name.
- In the navigation pane, choose SQL Audits.
- On the displayed page, select a time range in the upper right corner, select SQL audit logs to be downloaded in the list, and click Download above the list to download SQL audit logs in batches.
Alternatively, select an audit log and click Download in the Operation column to download an individual SQL audit log.
- The following figure shows the SQL audit log content. For field descriptions, see Table 1.
Figure 1 TaurusDB for PostgreSQL audit logs
Table 1 Audit log field description Field
AUDIT:
Fixed prefix, which identifies an audit record.
AUDIT_TYPE
Audit type. The value can be SESSION, OBJECT, or CLIENT_AUTHENTICATION.
STATEMENT_ID
Unique statement ID for this session.
SUBSTATEMENT_ID
ID of each substatement in the main statement.
CLASS or AUTHENTICATION_RESULT
Operation type.
- CLASS: The value depends on the pgaudit.log options, and can be READ or ROLE.
- AUTHENTICATION_RESULT: The value can be SUCCESS or FAIL.
PID
Process ID.
STATEMENT_START_TIME
Statement start timestamp, in us.
connection_status
Session status, which is usually the returned error code of a statement. If the statement is successfully executed, the value 0 is returned.
APPLICATION_NAME
Application name, such as PSQL and JDBC.
USER_NAME
Username for logging in to the database.
DATABASE_NAME
Name of the database that was logged in to.
REMOTE_HOST
IP address of the host used for login.
COMMAND
Type of the SQL command, such as ALTER TABLE and SELECT.
OBJECT_TYPE
Object type, such as TABLE, INDEX, and VIEW.
OBJECT_NAME
Object name.
STATEMENT
Content of the SQL statement executed at the backend.
PARAMETER
Parameter value.
