Updated on 2026-01-15 GMT+08:00
Viewing Parameter Change History
You can view the change history of DB instance parameters or custom parameter templates.
The change history for an exported or custom parameter template is initially blank.
Viewing Change History of a DB Instance
  2. Click in the upper left corner and select a region.
  3. Click in the upper left corner of the page and choose Databases > TaurusDB.
  4. On the Instances page, click the instance name.
  5. In the navigation pane, choose Parameters. On the displayed page, click Change History.
    You can view the parameter name, original parameter value, new parameter value, modification status, modification time, application status, and application time.
Viewing Change History of a Parameter Template
  4. Choose Parameter Templates in the navigation pane. On the Custom Templates page, click the target parameter template.
  5. On the displayed page, choose Change History in the navigation pane.
    Figure 1 Viewing parameter change history
    You can view the parameter name, original parameter value, new parameter value, modification status, and modification time.
    You can apply the parameter template to DB instances as required by referring to Applying a Parameter Template.
