Resetting the Administrator Password to Restore root Access
You can reset the administrator password only through a primary instance. The new password is applied immediately without rebooting the instance.
If you forget the password of the administrator account root, you can reset it.
Precautions
- If the password you provide is regarded as a weak password by the system, you will be prompted to enter a stronger password.
- If you have changed the administrator password of the primary DB instance, the administrator password of the standby DB instance will also be changed.
- The time required for the new password to take effect depends on the amount of service data currently being processed by the primary DB instance.
- To protect against brute force hacking attempts and ensure system security, change your password periodically, such as every three or six months.
Method 1
- Click
in the upper left corner and select a region. - Click
in the upper left corner of the page and choose Databases > TaurusDB. - On the Instances page, locate the target DB instance and choose in the Operation column.
- If you have enabled operation protection, click Send Code in the displayed Identity Verification dialog box and enter the obtained verification code. Then, click OK.
Two-factor authentication improves the security of your account and cloud product. For details about how to enable operation protection, see Identity and Access Management User Guide.
- Enter and confirm the new password.
Keep this password secure. The system cannot retrieve it.
The password must consist of 8 to 32 characters and contain at least three types of the following characters: uppercase letters, lowercase letters, digits, and special characters (~!@#$%^*-_=+?,). The password must be strong to avoid being easily cracked, as weak passwords will block your operation. Enter a strong password and periodically change it for security reasons.- To submit the new password, click OK.
- To cancel the reset operation, click Cancel.
Method 2
- Click
in the upper left corner of the page and choose Databases > TaurusDB. - On the Instances page, click the instance name.
- On the Basic Information page, find Administrator and click Reset Password under it.
