Supported Extensions
The following table lists the extensions supported by the latest minor versions of TaurusDB for PostgreSQL. You can use SELECT name FROM pg_available_extensions; to view the extensions supported by your DB instance.
The extensions mysql_fdw, dblink, pgsql-ogr-fdw, postgres_fdw, and tds_fdw are used to access data stored in remote database servers. Before using any of them, ensure that the server IP addresses of the two DB instances are in the same VPC and subnet.
| Extension Name | PostgreSQL 16 |
| address_standardizer | 3.4.3 |
| address_standardizer_data_us | 3.4.3 |
| amcheck | 1.3 |
| auth_delay | 2 |
| autoinc | 1 |
| dblink | 1.2 |
| dict_int | 1 |
| dict_xsyn | 1 |
| fuzzystrmatch | 1.2 |
| hll | 2.18 |
| insert_username | 1 |
| intagg | 1.1 |
| intarray | 1.5 |
| ip4r | 2.4.2 |
| isn | 1.2 |
| jsonb_plperl | 1 |
| lo | 1.1 |
| moddatetime | 1 |
| mysql_fdw | 2.9.1 |
| orafce | 4.14 |
| pageinspect | 1.12 |
| passwordcheck | 2 |
| pgAudit | 16 |
| pg_bigm | 1.2 |
| pg_buffercache | 1.4 |
| pg_cron | 1.6.2 |
| pg_freespacemap | 1.2 |
| pg_hint_plan | 1.6.1 |
| pg_partman | 5.0.1 |
| pg_prewarm | 1.2 |
| pg_qualstats | 2.1.1 |
| pg_repack | 1.5.2 |
| pg_roaringbitmap | 0.5.4 |
| pg_stat_statements | 1.1 |
| pg_sugry | 1 |
| pg_trgm | 1.6 |
| pg_visibility | 1.2 |
| pgl_ddl_deploy | 2.2.1 |
| pgrouting | 3.6.1 |
| pgrowlocks | 1.2 |
| pg_sql_history | 1.2 |
| pgstattuple | 1.5 |
| plpgsql | 1 |
| plperl | 1 |
| plproxy | 2.11.0 |
| postgis | 3.4.3 |
| postgis_raster | 3.4.3 |
| postgis_sfcgal | 3.4.3 |
| postgis_topology | 3.4.3 |
| postgres_fdw | 1.1 |
| rds_hwdrs_ddl | 1 |
| rds_hwdrs_privs | 1 |
| rds_pg_sql_ccl | 1 |
| rum | 1.3.13 |
| seg | 1.4 |
| sslinfo | 1.2 |
| tablefunc | 1 |
| tcn | 1 |
| tds_fdw | 2.0.4 |
| test_decoding | 2 |
| tsm_system_rows | 1 |
| tsm_system_time | 1 |
| unaccent | 1.1 |
| uuid-ossp | 1.1 |
| xml2 | 1.1 |
