Updated on 2026-01-20 GMT+08:00
Checking and Exporting Backup Information
You can export backup information of TaurusDB for PostgreSQL instances to an Excel file for further analysis. The exported information includes the DB instance name, backup start and end time, backup status, and backup size.
  2. Click in the upper left corner and select a region.
  3. Click in the upper left corner of the page and choose Databases > TaurusDB.
  4. In the navigation pane, choose Backups.
  5. Select one or more backups and click Export.
    Alternatively, on the Instances page, click the instance name. In the navigation pane, choose Backups. On the Full Backups tab, select one or more backups and click Export.
    • Only the backup information displayed on the current page can be exported. The backup information displayed on other pages cannot be exported.
    • The backup information is exported to an Excel file for your further analysis.
  6. Check the exported backup information.
